Component Abuse Challenge
The Component Abuse Challenge celebrates the use of LEDs as photosensors, capacitors as microphones, and resistors as heat sources.
Tuesday, September 16, 2025 10:00 am PST - Tuesday, November 11, 2025 10:00 am PST Local time zone:
This contest has ended, and the winners have been announced. Thank you to everyone who joined in on the challenge fun!
Be sure to check out all the other amazing projects that joined this challenge.
Introduction:
In theory, all parts are ideal and do just exactly what they say on the box. In practice, everything has its limits, most components have non-ideal characteristics, and you can even turn most parts’ functionality upside down.
The Component Abuse Challenge celebrates the use of LEDs as photosensors, capacitors as microphones, and resistors as heat sources. If you’re using parts for purposes that simply aren’t on the label, or getting away with pushing them to their absolute maximum ratings or beyond, this is the contest for you.
If you committed these sins against engineering out of need, DigiKey wants to help you out. They’re probably got the right part, and they’re providing us with three $150 shopping sprees to give out to the three top projects. (If you’re hacking just for fun, well, you’re still in the running.)
This is the contest where the number one rule is that you’ve got to break the rules, but the project has to work anyway. You’ve got until November 11th. Let the parts know no mercy!
Honorable Mention Categories:
  • Bizarro World: There is a duality in almost every component out there. Speakers are microphones, LEDs are light sensors, and peltier coolers generate electricity. Turn the parts upside down and show us what they can do.
  • Side Effects: Most of the time, you’re sad when a part’s spec varies with temperature. Turn those lemons into lemonade, or better yet, thermometers.
  • Out of Spec: How hard can you push that MOSFET before it lets go of the magic smoke? Show us your project dancing on the edge of the abyss and surviving.
  • Junk Box Substitutions: What you really needed was an igniter coil. You used an eighth-watt resistor, and got it hot enough to catch the rocket motor on fire. Share your parts-swapping exploits with us
A big thanks to Joe Kim for the amazing art!
Powered by DigiKey:
Examples:
Need some inspiration? Here are some projects to check out that should get your ideas flowing:
Rules:
  • All entries must use a component to do something that it’s not intended to do, push it within a hair’s breadth of the maximum operating ratings, or get creative with the real-world non-idealities.
  • We want to learn from you. Document your project as well as you can so that we can follow along.
  • All entrants must agree to have the design published on Hackaday.
  • Employees and contractors of DigiKey, Supply Frame, Siemens, Arduino, and their immediate family members are ineligible to win, but are still encouraged to enter.
  • Rules and categories are subject to change and judges' decisions are final.
Important Reminder: Previously created projects may be submitted to the contest, but they must be updated within the timeframe of this contest. Previously created projects submitted with no updates will be disqualified.
... Read more »
View contest log
Enjoy this contest?
Cedric Honnet wrote 09/25/2025 at 01:09 • point
@Lutetium: is there a chance that this contest could be every year?
(I'm working on something quite relevant but it will take many months)
Nick wrote 11/10/2025 at 20:43 • point
@Lutheitum: is there a chance that this contest could be every 10 years?
(I’m working on something even bigger but it will take many years)
John Schuch wrote 09/16/2025 at 19:33 • point
Everyone who uses a '595 to drive LEDs has an entry in this contest.  :-)
Eager to get building?
Become a member and discover thousands of projects
