Testing ATRK Regulation – Mockup #1
A project log for Pwrblock 323
Reliable power for DUT testing: USB-C input, Python API, open hardware. Compact tool for labs, factories, and developers’ desks.
ioan-larionovIoan Larionov 09/24/2025 at 17:500 Comments
Our op-amp PCB is currently stuck somewhere in Finnish customs (classic…), so instead of waiting, we kicked off Mockup #1 testing without it.
The first experiment focuses on the ATRK input for output voltage regulation on the LM51772EVM. The datasheet isn’t very clear about how this feature behaves, so let’s figure it out ourselves.
Setup
Observations
At first glance, the DAC seems a bit nonlinear — maybe due to bias current? So we checked linearity directly.
Result: DAC looks fine. That means the nonlinearity is a quirk of the LM51772 itself. And that’s actually fine for us. All we need from ATRK is the ability to slightly trim Vout (no more than ±50 mV).
Results
Near the maximum output of 32 V, the trim resolution looks promising:
With an additional op-amp stage to amplify the DAC voltage into the desired range, resolution will only improve.
DAC StepsATRK dVVout dVdV/step
1000,080,060,0006
500,040,010,0002
Next steps
Once the op-amp PCB finally arrives, we’ll move on to testing ISET regulation, comparing direct ATRK control vs. buffered DAC inputs with op-amps.
