Log 4 — IoT Sensor Integration
A project log for Nectar Nest - The First True 3D Hive for Honey Pro
A fully modular beehive, designed for FDM 3D printing with thermal-insulating sandwich walls and IoT monitoring
diegoDiego • 09/17/2025 at 19:33•0 Comments
An optional ESP32 LoRa module with BME680 sensors monitors temperature, humidity, and air quality. The idea is to connect hives into a global open-data network for research and beekeeping optimization.
