Key features:
🧱 Sandwich walls: 20 mm thick, with two 1.6 mm outer skins and a 5% gyroid infill for insulation.
🔄 Modular design: Brood box, super, cover, roof — all stackable and combinable.
🐝 Anti-varroa bottom with removable tray and metal mesh slot.
🌡️ Weather-resistant PETG: food-safe, UV stable, and printable on consumer-grade machines.
📡 IoT expansion: ESP32 LoRa sensors for temperature, humidity, and hive health monitoring.
🌍 Maker-friendly: Designed for printers with 420×420 mm beds (e.g., Neptune 4 Max, Anycubic Kobra 3 Max, etc.).
Details
The complete assembled hive measures 41 × 41 × 70 cm and accommodates standard Langstroth-compatible frames (10 per brood/super box).
Main Components
Bottom board: Varroa-counting tray + mesh insert.
Brood chamber: Made of base adapter + honey super.
Honey super: Can be used standalone or stacked.
Escape board: Optional bee escape separator.
Inner cover: Space for feeder insert.
Roof: Insulating with chimney-effect air vents.
Diego
TheStumbler
Dimitrios Kallivroussis
ProgressTH
