The hive was intentionally designed to fit monolithic printing on 420×420 mm plates to avoid seams and assembly joints. We’re testing slicing strategies (Cura profiles, adaptive layers) to optimize print times.
A project log for Nectar Nest - The First True 3D Hive for Honey Pro
A fully modular beehive, designed for FDM 3D printing with thermal-insulating sandwich walls and IoT monitoring
