Hackaday.io Hackaday.io
Sign up Log in
Affordable World Healthcare
Our Robot Overlords Want Us to be Healty
jacob-christJacob Christ
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
570 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 0
  • Logs 3
    • View all
  • Instructions 0
  • Discussion 0
  • The 2017 Hackaday Prize
View Gallery
760
0
570
11
Team (1)
  • jacob-christJacob Christ
Join this project's team
Software
ongoing project
2017HackadayPrize
This project is submitted for
  • Design your concept
This project was created on 03/19/2017 and last updated 7 年前.
Description
Use ML (Maybe Google's TensorFlow) tied to a mobile application to provide frontline medical self help.
Files
Build Something That Matters 2017-03Mar-18.pdf
Foils from #HackadayUnconf 2017, Pasadena, CA https://www.meetup.com/Hackaday-Los-Angeles/events/238093158/
Adobe Portable Document Format - 1.09 MB - 03/19/2017 at 20:09
Preview
Project Logs
Collapse
  • TensorFlow Dependencies in Windows 10 64bit
    Jacob Christ • 04/01/2017 at 03:10 • 0 comments
    In my learning efforts I started to try to use the tflearn library. This depends on SciPy which depends on NumPy and Curses libraries. These libraries do not want to install easily using pip3. I think I have it working now and the goto site to get the wheel files (*.whl) seems to be this one:
    http://www.lfd.uci.edu/~gohlke/pythonlibs/
  • Installing TensorFlow
    Jacob Christ • 03/30/2017 at 05:15 • 0 comments
    You can tell TensorFlow is still very new! Today I finally got it working, the install instructions on the TensorFlow web page don't quite work. There is a bug in the 1.0 release that gets pulled down with the Python pip tool and you need to pull a build from the nightly builds. Thanks to google search it wasn't too hard to find the solution in a github issue:
    https://github.com/tensorflow/tensorflow/issues/7540
  • Build Something That Matters
    Jacob Christ • 03/19/2017 at 20:07 • 0 comments
    Yesterday in Pasadena, CA at the Hackaday Design Center I presented the talk uploaded above.
View all 3 project logs
Log In/Sign up to comment
Sign up with Github
OR
A 3-way OBD2 breakout board that allows you to monitor and route signals anywhere you want using simple jumper blocks and wires.
Project Owner Contributor
An OBD2 breakout to Sniff, Re-route, and More
macchinaMacchina
A simply front end to use a networked scanner on a Raspberry Pi from an OSX machine.
Simple Sane.d front-end for OSX
timescaleTimescale
A New, Free and Simple to use URL shortener for all to use
LinkOwl.net
bytetechByteTech
This is a project for a maker space i work at after seeing my Raspberry Pi in action they wanted their own to use slide show and info
Raspberry Pi demo's slide show ssh and more
hatterofthewasteHatterofthewaste
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Affordable World Healthcare", please tell us the reason.
Send message
Remove Member
