TensorFlow Dependencies in Windows 10 64bit
04/01/2017 at 03:10 • 0 commentsIn my learning efforts I started to try to use the tflearn library. This depends on SciPy which depends on NumPy and Curses libraries. These libraries do not want to install easily using pip3. I think I have it working now and the goto site to get the wheel files (*.whl) seems to be this one:
Installing TensorFlow
03/30/2017 at 05:15 • 0 commentsYou can tell TensorFlow is still very new! Today I finally got it working, the install instructions on the TensorFlow web page don't quite work. There is a bug in the 1.0 release that gets pulled down with the Python pip tool and you need to pull a build from the nightly builds. Thanks to google search it wasn't too hard to find the solution in a github issue:
Build Something That Matters
03/19/2017 at 20:07 • 0 commentsYesterday in Pasadena, CA at the Hackaday Design Center I presented the talk uploaded above.
Jacob Christ
