I had the idea to build a cheap, 360° continious rotation servo by using a very common 24BYJ-48 stepper motor and two potentiometers.
The idea was to use two 20k potentiometers on the shaft of the stepper. When poti is in its dead zone, the other poti could be used.
The hole in the middle hat to be squared a bit to fit onto the shaft by using a solding iron.
There's a typo in the title. *Continuous.
