Hardware Connection
As shown in the diagram, connect the red, green, and blue pins of the RGB-LED module to the Arduino pins 1, 2, and 3 on the development board. The RGB-LED used here is a common cathode LED, with the common pin connected to GND. If using a common anode LED, it should be connected to 3.3V.
RGB-LED Module Schematic:https://oshwhub.com/jinleili/rgb-led-module
Code Analysis
#include "BLEDevice.h"
// Choose the RGB LED type
// #define AnodeRGB
#define CathodeRGB
// Choose 3 PWM pins for RGB LED pins refer to the pinmap of using board
#define LED_RED 1
#define LED_GRN 2
#define LED_BLU 3
#define UART_SERVICE_UUID "6E400001-B5A3-F393-E0A9-E50E24DCCA9E"
#define CHARACTERISTIC_UUID_RX "6E400002-B5A3-F393-E0A9-E50E24DCCA9E"
#define CHARACTERISTIC_UUID_TX "6E400003-B5A3-F393-E0A9-E50E24DCCA9E"
#define STRING_BUF_SIZE 100
BLEService UartService(UART_SERVICE_UUID);
BLECharacteristic Rx(CHARACTERISTIC_UUID_RX);
BLECharacteristic Tx(CHARACTERISTIC_UUID_TX);
BLEAdvertData advdata;
BLEAdvertData scndata;
bool notify = false;
void readCB(BLECharacteristic* chr, uint8_t connID)
printf("Characteristic %s read by connection %d \n", chr->getUUID().str(), connID);
void writeCB(BLECharacteristic* chr, uint8_t connID)
printf("Characteristic %s write by connection %d :\n", chr->getUUID().str(), connID);
uint16_t datalen = chr->getDataLen();
if (datalen > 0) {
if (chr->readData8() == '!') {
uint8_t command[datalen];
chr->getData(command, datalen);
if (command[1] == 'C') {
// print hex
printf("Color command R = %x G = %x B = %x \n", command[2], command[3], command[4]);
// print decimal
// printf("Color command R = %d G = %d B = %d \n", command[2], command[3], command[4]);
#if defined(CathodeRGB)
analogWrite(LED_RED, command[2]);
analogWrite(LED_GRN, command[3]);
analogWrite(LED_BLU, command[4]);
#elif defined(AnodeRGB)
analogWrite(LED_RED, (255 - command[2]));
analogWrite(LED_GRN, (255 - command[3]));
analogWrite(LED_BLU, (255 - command[4]));
#else
printf("Error, please choose the RGB LED type \n");
#endif
} else {
Serial.print("Received string: ");
Serial.print(chr->readString());
Serial.println();
void notifCB(BLECharacteristic* chr, uint8_t connID, uint16_t cccd)
if (cccd & GATT_CLIENT_CHAR_CONFIG_NOTIFY) {
printf("Notifications enabled on Characteristic %s for connection %d \n", chr->getUUID().str(), connID);
notify...
Ai-Thinker
Gombe
Aleksei
bobricius
