Day 14: Edge Board Color Sensor Board
09/22/2023 at 18:07 • 0 commentsColor Sensor board with the VEML6040 chip for color detection with built in led for low light situations.
This also has mousebites on the sensor part of the board so it can be removed and the color sensor can be mounted closer and in a smaller form factor than the larger assembly.
source files can be found here: https://github.com/evezor/v0_color_sensor_board
This board uses the Evezor Stamp STMF405 MCU
Day 13: Edge Board Potentiometer Bar Graph
09/21/2023 at 13:46 • 0 commentsAn Edge boad with two buttons, two potentiometers and 2 multiplexed led bar graphs
Source files can be round here: https://github.com/evezor/v0_potentiometer_board/
Day 12: Edge Board Joypad
09/20/2023 at 11:50 • 0 commentsAn edge board shaped like a joypad. It has 2 analog inputs, 4 light up buttons, start and select pushbuttons, a dpad, a buzzer and a 5 position neopixel strip.
source files can be found here: https://github.com/evezor/v0_joypad
Day 11: Edge Board 7 Segment Display
09/19/2023 at 12:16 • 0 commentsAn edge board containing qty(2), 4 character 7 segment displays
source files can be found here: https://github.com/evezor/v0_7_segment_display_board
Day 10: Voltage Regulator Board
09/18/2023 at 02:11 • 0 commentsAn edge board with an adjustable voltage regulator circuit capable of supplying 2A of current
source files can be found here: https://github.com/evezor/v0_regulator_board
Day 9: Edge Board Real Time Clock
09/16/2023 at 11:09 • 2 commentsThis board has a real time clock module along with a battery backup. It will keep time over power cycles and also track days/months/years and time of day.
source files can be found here: https://github.com/evezor/v0_real_time_clock_board
Day 8: Edge Board Weather Station
09/15/2023 at 10:55 • 3 commentsThis weather station board features a barometric pressure sensor, an ambient light sensor and a temperature and humidity sensor.
Source files can be found here: https://github.com/evezor/v0_weather_station_board
Day 7: Edge Board Servox16
09/14/2023 at 11:58 • 0 commentsThis board uses the Evezor Stamp STMF405 MCU
source: https://github.com/evezor/Evezor-Stamp-STMF405
An edge board containing a PCA9685 driver chip capable of controlling 16 servos or LEDs. The board also contains 2 pushbuttons and a dpad for easy control/ debugging. Servo power must be supplied from external source
source files can be found here: https://github.com/evezor/v0_servox16_board
Day 6: Edge Development Board and Sidekick
09/13/2023 at 23:40 • 0 commentsAn edge board that is meant to be a development board that breaks out all the pins. And a second board that is meant to assist, that has a small prototyping area.
Edge Devboard
Sidekick
Source can be found here: https://github.com/evezor/v0_devboard_and_sidekick
Day 5: B3 Test Board
09/13/2023 at 01:13 • 0 commentsThe B3 board was meant as a test board to test the Edge networking and to test the fit with the edge stamp board.
There are a couple leds, buttons, a potentiometer and connections for the canbus.
Source files can be found here: https://github.com/evezor/b3_board
