11Testing
It’s time to test the Pocket Glow. Start by switching on each button one at a time to make sure both the cool white and warm white LED strips are functioning properly. The alternating arrangement of the strips, combined with the diffuser, creates a soft, balanced, and pleasant glow.
Next, test the brightness under different conditions—indoors, outdoors, and in complete darkness—to see how well the light performs. I also checked the power bank module output to ensure it supplies stable power, and it worked exactly as expected. One of the best features of this module is that, in case of an emergency, it can double as a power bank to charge your smartphone quickly and reliably.
With everything working smoothly, your Pocket Glow is officially ready—a compact, versatile, and stylish lighting companion for camping, outdoor adventures, or even everyday use at home.
12Conclusion
The Pocket Glow is more than just a small DIY build—it’s a practical and reliable piece of gear that makes outdoor adventures more enjoyable. With its compact design, balanced dual-color LED lighting, and rechargeable battery, it’s the perfect companion for camping, late-night walks, or simply creating a cozy atmosphere in your backyard. The addition of a diffuser ensures soft, glare-free illumination, making the light comfortable for both utility and relaxation.
The Pocket Glow has created with the same intention—to combine functionality with simplicity, and to offer a handmade tool that makes time spent outside more convenient and enjoyable.
Whether you’re packing for a camping trip or just adding a touch of warmth to your evening outdoors, the Pocket Glow shows how even a small DIY idea can light up big adventures.
Next Builder
