_________________________________
6-Channel Visible Spectral_ID Device with Electronic Shutter and Smart Interface
article http://www.azosensors.com/news.aspx?newsID=11749
distribution http://ams.com/eng/content/download/976611/2309519/498778 (Digi-Key $4.90)
Doesn't that article also mention the AS7262, with sensors at 450, 500, 550, 570, 600, and 650 nm?
Indeed, you might as well combine the -2 and -3, whack on a VEML6075
http://www.vishay.com/docs/84304/veml6075.pdf
and cover the range from UV to NIR with 14 channels. They're first to market with a design that works with conventional Si processing.
I'd still like to experimentally prove the bandgap defined wavelength selectivity of the initial concept though. Plus they prove the form factor and function of The Optical Inch has merit ;-)
Indeed these filter baed sensors have been around for a while with their most popular incarnation being 4-channel color temperature sensor for lighting feedback and monitor calibration.
