Hi everyone,
I’m Nischay Sai, an engineering student. I’ve been developing a modular shape-changing robot made up of small independent robotic units.
Each unit acts as both the body and actuator, using miniature motors to enable multi-directional rotation and self-reconfiguration. The goal is to allow these modules to connect and rearrange into different geometric structures or motion patterns.
⚙ Technical Overview:
Actuators: Micro servo motors (used as both body and joint)
Control System: ESP32 microcontroller with I²C expanders
Power: 5V DC via shared bus
Communication: Serial & Web-based interface for control
Software: Python + web dashboard (for direction and motor mapping)
Design: Each module can rotate 360°, allowing structural flexibility
💡 Inspiration:
Inspired by adaptive, modular robotics research and self-reconfigurable systems in robotics.
The focus is on creating low-cost micro-scale shape-changing robotics that can adapt form factors dynamically.
🎯 Future Work:
Adding magnet-based docking between modules
Improving motion synchronization
Implementing distributed control logic
Full working video :
Looking for:
Feedback on the modular design approach or ideas for better control synchronization between multiple units.
NISCHAY SAI D R
Stanislav Britanishskii
Blade Master
Keith Elliott
