Implementing Paging
A project log for MooseOS
x86 Operating System that runs on QEMU, Bochs and physical PCs.
ethan-zhangEthan Zhang 10/11/2025 at 06:040 Comments
Retroactive Log – September 12th (Reconstructed from memory and commit logs)
I realised that I was missing something in my operating system, which is, of course, paging. To be fair, i didn't have much use for it, but I realised that since this operating system was rapidly expanding, paging will soon be useful (my realisation would turn out to be true when I decided to add ELF loading. More on that in future logs). Setting up paging was straightforward; all I had to do was follow the OSDev wiki and set it up, and set up paging for applications that require it (eg, terminal). Doing this was surprisingly simple, since paging is usually very well documented, and I experienced no dramas setting this up.
