Improving Ease of Voltage Limit Adjustments, plus others!
A project log for PROTECT Series: DC Power Management Modules
Protect is a series of high-quality DC Power Protection Modules designed for makers using the best eFuses and automotive power path ICs.
pn-labsPN Labs 10/27/2025 at 06:140 Comments
- Changing from using potentiometers to using resistor arrays with DIP switches to improve accuracy and remove the need for a user to have their own resistance meter to set the required Over and Under voltage cutoffs.
- Since there is no longer a potentiometer being used, it is no longer necessary to restrict the operating voltage ranges to 30 V and 60 V versions. Just one 4-60 V version will be made targeting 30 A continuous current.
- A lower voltage version going up to 30 V but doing higher amperage is very possible, just by using a higher current connector and using lower resistance FETs. Interested in hearing what projects could use this.
- The over-current circuit breaker will also use its own DIP switch for ease of use
