First Functional Prototype In - Sponsored by PCBWay!
A project log for PROTECT Series: DC Power Management Modules
Protect is a series of high-quality DC Power Protection Modules designed for makers using the best eFuses and automotive power path ICs.
pn-labsPN Labs 11/25/2025 at 07:310 Comments
Its been a while since I updated this feed, so here it is with progress:
- Changed from DIP switches back to potentiometers for voltage adjustment - continuous adjustment is better for something as sensitive as voltage cutoffs
- Started designing a calibration jig that can measure the voltage cutoffs of each board. This is because when doing something as critical as undervoltage protection of lithium cells, having a typical 1-3% error in the voltage cutoff equation (as seen from internal testing of Protect modules) makes a difference in protecting the battery and the amount of energy that can be drawn before shutdown.
- First functional prototype has been received by PCBWay and hand assembled! A few differences I noticed when ordering compared to other board houses:
The prototypes cutoff at the right voltages and everything seems to be in order, so the next step is to do some preliminary power testing to see how the board copes with in-rush current, plus its steady state thermal profile at different power levels (2 FETs or 3 in parallel?).
