Ethernet in Your SSD Slot — The M.2 B-Key Network
Because who said your M.2 slot can’t speak Ethernet, Wi-Fi, and motion?
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
What if that lonely M.2 slot on your board could do more than just host an SSD?
Meet the M.2 B-Key Network Adapter — a compact hardware module that transforms your M.2 interface into a network-enabled expansion port with Ethernet, Wi-Fi, USB-UART, and motion sensing all packed into one sleek 2280-sized PCB.
This board is powered by the Skylab SKW92 module, combining Wi-Fi and Ethernet PHY inside a tiny footprint. Add an MPU6050 IMU for motion sensing, a CH340C USB bridge for easy programming, and a USB-C port for power and serial access — and you’ve got a smart, hackable network card that fits where your SSD used to live.
