One Firmware to rule them all
11/14/2025 at 20:47 • 0 commentsAdded automatic detection of the board which maps the pins automatically.
New packaging for the bridge, more compact and wall mounted![]()
New MQTT Bridge, same firmware
11/11/2025 at 19:22 • 0 commentsexisting complex firmware works perfectly on another non LCD ESP32 S3 device with CAN transceiver integrated ! Only change needed are the pins<->GPIO mappings. Future version should include auto board detection.
couple of pictures with new enclosure![]()
Added Serial via OTA
11/09/2025 at 20:15 • 0 commentsI was getting tired of running up and down to the attic or debug in the attic itself so I've implemented a serial output OTA display
Boost feature + Installation
11/07/2025 at 19:32 • 0 commentsAdded boost feature and display of remaining time
Fixed few bugs and installed 2 devices with same firmware: one in bridge mode and one in remote mode. Home Assistant integration successful![image]()
![image]()
Time Synced !
10/26/2025 at 19:48 • 0 commentsSniffing the time CAN commands was fairly difficult but it works now: the time of the MVHR can now be synced on a regular basis with NTP servers.
This is useful since the time on the device tends to deviate quickly
New Feature: Remote Client Mode
10/25/2025 at 15:30 • 0 commentsThis mode can be enabled in secrets.h. When set to true, the device is no longer a MQTT bridge but requires another MQTT bridge and MQTT broker. Check this repo for implementation of the bridge :https://github.com/dardhal/comfoair-esp32.
I will also publish my own version in a single board which can be hooked up via the RJ45 port directly but here's a preview in the meantime
The benefit of this mode is the display doesn't have to be hooked up to the Comfonet and can be installed anywhere in the house, as a secondary controller.
The diagram below illustrates the architecture in the two different modes![]()
Demo of the unit
10/23/2025 at 11:15 • 0 comments
vincentmakes
