DekThing - DeskThing but diy hardware
CarThing but its DekThing
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
WIP
parts (affiliate links):
https://s.click.aliexpress.com/e/_c4MVwhGf > OPTION - 2.4 inch no touch
https://s.click.aliexpress.com/e/_c3lYIFLV
how to do:
download repo
put ssid and password in code.
flash esp.
wire it:
SCLK 13
MOSI 23
CS 15
DC 2
RST 4
VCC 3v3
GND GND
download node.js
https://nodejs.org/en/download
cd to server folder
run npm install
run node esp_proxy.mjs
you shud see ESP proxy running at http://localhost:5000
if so, cool.
now install spicetify if you dont alr have it.
https://spicetify.app/docs/getting-started
once fully installed, open spicetify-extension.js and change the ip to the one your esp has
(make sure to change your esp to static ip on your router)
spicetify config-dir
coppy the spicetify-extension.js file to the extentions folder that popped up.
now run spicetify config extensions spicetify-extension.js next run spicetify apply
boom.
