Manual pose control works!
11/03/2025 at 21:11 • 0 commentsThere are several modules within the LCIE that all work together to make it work. One of these is the SPM or Show Performance Module.
The biggest thing about this module is its designed to be as easy to program, and as easy to use as possible. How its supposed to work is that it takes in a Multi-track MIDI files for an input, then certain tracks are assigned to changing the poses of whatever character is on screen.
So to test this in Unity, the first thing we needed to do was make sure characters can cleanly transition from one static pose to the other.
Here is a youtube video about said progress.
Jake Ferguson
