Planning
A project log for F.I.E.B (Friendly Interactive Exploring Bot)
A Can-sized robot powered by an ESP32, combining motion, sensors, and expressive displays to explore perception and personality.
adAd 11/05/2025 at 14:000 Comments
The Journey So Far
This desktop robot began as an idea to combine sensors, movement, and personality into a palm-sized machine — one that could navigate its environment and display emotions through simple expressive cues.
Core Platform: ESP32 Brain
The robot’s main controller is an ESP32-WROOM-32, chosen for its dual-core performance, built-in Wi-Fi and Bluetooth, and flexible I/O support. Its processing power allows simultaneous control of motors, sensors, and display outputs — all while maintaining network connectivity for future OTA updates and data logging.
The ESP32 handles:
PWM motor control for precise movement
I²C communication with all sensors and OLED displays
Battery monitoring and power management
Serial debugging and configuration
Drive System: Two Wheels + Caster
Mobility is achieved through a two-wheel differential drive system powered by N20 500RPM micro gear motors, providing a balance between torque and speed.
Steering is accomplished by varying the speed of each motor — no servo steering is required.
To stabilize the chassis, a single rear caster (ball-style) supports the frame, keeping the bot balanced while allowing smooth pivot turns.
Power System
The bot runs on a 3.7 V 2000 mAh Li-ion battery, offering solid runtime for its small form factor.
A TP4056 USB-C charging and protection module manages charging and discharge safety. The power rail splits to feed:
ESP32 logic (3.3 V regulated)
Motor driver board (5 V or VIN depending on configuration)
Sensor and display I²C bus (3.3 V)
The goal is to later integrate automatic charging via magnetic pogo pins or a simple docking plate.
Motor Driver
A compact dual-channel PWM motor driver connects to the ESP32. Each motor is controlled via one PWM and one direction pin. This allows proportional speed control and smooth turning maneuvers.
Sensors: Environmental Awareness
The robot’s “eyes” are four VL53L0X Time-of-Flight sensors, placed strategically around the chassis:
Front-left and front-right for collision avoidance
Left and right sides for wall following and spatial mapping
Rear or angled sensor (optional) for backing awareness
Each sensor uses unique I²C addresses, set dynamically at startup to share the same bus.
An accelerometer (connected via I²C) provides tilt detection and motion feedback — letting the bot understand its orientation or detect if it’s been lifted or knocked.
Displays: Expression and Feedback
Two 0.96″ OLED displays (128×64, I²C) are mounted at the front.
Display 1: System data (battery level, IP, sensor readings, etc.)
Display 2: Animated “eyes” — giving the bot a bit of personality
Both displays share the same bus (address 0x3C), but a multiplexer or secondary I²C address can be used to differentiate them.
Layout and Wiring
Everything fits around a custom 3D-printed chassis, designed to roughly match the footprint of an Arduino Uno — compact but with layered sections for electronics and sensors.
The current wiring includes:
ESP32 GPIOs for both motor channels
Shared I²C for OLEDs, ToF sensors, and accelerometer
Power distribution from the TP4056 board
Motor driver VIN from battery rail
Battery sense pin for voltage monitoring
Software and Control Logic
Initial sketches handle:
Basic motor testing (PWM forward/reverse)
I²C detection of sensors and displays
Data visualization on OLED
Serial feedback for debugging
The next software milestones include:
Sensor fusion for obstacle detection
Motion logic with avoidance behavior
Display animations for idle/active states
OTA update integration
Wi-Fi dashboard for sensor readouts
Chassis Design
The chassis design is being modeled in Fusion 360, with considerations for:
Two motor mounts with alignment brackets
Rear caster housing
Front plate for ToF sensors and OLEDs
Detachable top shell for battery and board access
Clean internal wire routing
charging dock contact point, modular sensor mounts, or detachable head unit for easier prototyping.
