This is my little dream project so that i can run all the machines before my own time in a handy package on a real terminal, i am from 1982 and almost all machines this little project will run are from before that, from the dawn of home computer time. Ok, the PDP11 is a stretch here, but nobody would have stopped a wealthy enthusiast from owning one, or? ;)
I might never own one of the real machines this project will run but my motto is "Retro for the masses, not for the classes" anyway, so alas, lets make that dream come true.
It all started when i stumbled upon the sourcecode of the Pico_1140 by Ian Schofield, bodged a board and SD card together and had some fun with it. The emulation seemed solid enough but the setup was janky at best. Looked at it and got to work, adding a translation layer from VT100 or ADM-3A to either one, adding a nice menu and then adding, as of this writting, two other guest until i were where i am now.
The project was on hiatus for a year as i had family problems to attend to and to fix up, but now i finally have time again to work on this.
Whats currently implemented:
- PDP11 based on Pico_1140
- Runs Unix V6.
- Runs RT11.
- Any other OS from that era will surely boot.
- Z80 based on the implementation of the Z80 MBC2, reimplemented without using that projects code.
- Can run all versions of CP/M.
- Runs Fuzix.
- Surely runs many more.
- Apple 1
- With injection of either binaries or text files.
- Everything accessible trough a fancy TUI!
Whats next or in the works:
- An orthodox filemanager, i want this system to be truly stand-alone.
- Being able to switch disk images around.
- Guests:
- My own Z80 machine, LionsZ80
- Commodore KIM-1 and PET (with translation to ASCII as near as possible, with DECs graphic symbols and IBM/DOS extended ASCII selectable)
- CHIP8, maybe even as a full 1802 emulation.
- SC/MP, always wanted one, now i do my own ;)
- SWTPC 6800
I will also sell some kits on Tindy later, the two SMD parts will be pre-soldered. Can't sell fully soldered ones or i would need to mess with the Stiftung EAR and Take-e-way, not for a hobby project, no thanks. ;)
Code and board files can be found here: https://github.com/bastetfurry/TheSeventiesBoard
Alexandra Bastet Stehr
Augusto Baffa
Matthew James Bellafaire
Michael Rangen
andriy.malyshenko
Is there a schematic & BOM please?
