Hackaday.io Hackaday.io
Sign up Log in
SOLAR BJT charger SEE THE VIDEO
My idea is to build a small solar panel using 24 power transistors in a TO3 package.
gfresourcesvideogfresources.video
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
0 comments
7 followers
  • Description
  • Details
  • Files 0
  • Components 1
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
Public Chat
0
7
8
Team (2)
  • gfresourcesvideogfresources.video
  • maxMax
Join this project's team
  • Video
completed project
hardware
This project is submitted for
  • Component Abuse Challenge
This project was created on 11/11/2025 and last updated a month ago.
Description
My idea is to build a small solar panel using 24 power transistors in a TO3 package. To do this, I'll uncover the transistors so the silicon die is exposed and connect the collector - base and emitter - base junctions in parallel to generate a higher current. I'll use 25 transistors, which I'll attach to an insulating support with screws, and made the electrical connection in the other side by wrapping metod. After some research, I decided to arrange five series of five transistors in parallel to achieve a specific voltage and current. I then had to design a small step-up switching device to raise the voltage to 5V so I could use it to charge a smartphone. This idea and implementation is purely experimental obviously, a solar panel has a very different energy output, but I wanted to demonstrate how a handful of transistors can be used in a very alternative way.
Details
Components
  • 25 × Power NPN BJT
Log In/Sign up to comment
Sign up with Github
OR
Ultra low power device without batteries, zero maintenance, everlasting and environment friendly
Project Owner Contributor
Supercaps Solar Panel project
gosGos
Supplyframe DesignLab: 2022 Hackada…
A low cost and high efficiency Maximum Power Point Tracking (MPPT) charge controller with multiple inputs for solar panel setups.
MultiMPPT
leonardo-wardLeonardo Ward
In a world where transistors are cheap and everywhere, this project's aim was to use none of them at all.
1Hz solar powered pendulum uses no transistors
wouter-minjauwWouter Minjauw
The 2017 Hackaday Prize
A perpetually running wireless sensor mote.
Open SolarMote
dhqdhq
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "SOLAR BJT charger SEE THE VIDEO", please tell us the reason.
Send message
Remove Member
