Zicada - DIY Zigbee Multisensor
Open-Source Temperature, Humidity, and Contact Sensing
Zicada is a DIY Zigbee sensor based on Nordic’s nRF52840 SoC. It combines a temperature and humidity sensor with a hall effect switch, making it suitable for both climate and door/window monitoring. Zicada is optimized for ultra-low power consumption, running at just 6µW in standby. This allows it to operate on a rechargeable AAA battery for 2 years or longer. It is fully compatible with Home Assistant (ZHA) and Zigbee2MQTT.
Some of the key features:
• Temperature, humidity and contact sensing
• Zigbee 3.0 end device
• Compatible with Home Assistant (ZHA) and Zigbee2MQTT
• Ultra-low power consumption (6µW in Standby)
• 2+ years of battery life
• Supports AAA cells from 0.9V to 1.5V
• Small sized (62 x 15 mm) and fully 3D-printed case
Layout files, code and STLs on GitHub: https://github.com/CoretechR/Zicada
If you’re using a smart home system, chances are you already have several Zigbee devices around. While there are some nice commercial options, the vast majority of Zigbee sensors are tightly closed designs with proprietary firmware and rely on disposable lithium coin cells. I wanted to take a different path with this project: a fully open-source Zigbee sensor that runs on rechargeable NiMH cells - without sacrificing battery life or functionality.
This project was a classic case of “It can’t be that difficult”. While developing the hardware and optimizing it for low power was familiar territory, the software side turned out to be extremely challenging.
  • 2026 Upgrade: Adding a Light Sensor
    Max.K • 02/08/2026 at 18:56 • 0 comments
    Over the past few months I have been using the Zicada boards with HomeAssistant. So far, the results looks promising but are a little ambiguous. On two sensors, the battery life seems great with 88% charge left after rougly 3 months. These batteries should last for another year before needing to be recharged. But a third sensor, which has been running for the same duration, is now at 60% already. I am pretty sure this is not a hardware issue and the sensor might be performing better after a reset.
    There are a few little other issues or bugs left, where I am not sure whether this is due to my design or just Zigbee's overall complexity. For example, devices might take a few tries to complete their interview. Or some attributes are not reported at all, requiring a reset of the device. But usually, once everything work with a particular sensor, it stays that way.
    I have gotten some great feedback from the YouTube video. A few people noticed the lack of airflow to the temperature and humidity sensor. This is a valid point, since the gap between the case and button only lets very little air through, making the sensor react slower than it needs to. So I designed an updated version of the case with holes for improved airflow.
    Since I wanted to order a few more PCB for myself, I wanted to include another feature, that was mentioned a few times: A light sensor. On the PCB, there was just enough space near the button for a TI OPT3001 brightness sensor. This little sensor uses the existing i2c bus on the board for communication, so no more pins or routing were needed. This sensor looks really gorgeous with its translucent case, measuring only 2x2mm.
    The firmware needed some updates to read the sensor and to integrate the Zigbee illuminance cluster. Luckily, Zephyr comes with a driver for the OPT3001, so the sensor was up and running in no time. One problem with the driver was, that it forced the sensor in a continous mode, where it adds around 4µA to the power draw (the battery voltage is stepped up, so the sensor actually only draws 2uA @ 2.2V). Instead of modifying the driver, I am just overwriting the mode setting by writing to the register directly via i2c. The sensor now only wakes up when is needed. This got the power draw of the entire board down to 7.2µA, only 1µA more than before the addition of the light sensor.
    The reset button already has a translucent center since it used for the status LED. I increased the size of the button to let more light in. The button is directly above the light sensor so this should be enough to get a relative estimate of a room's brightness. Of course, this will not be a very precise measurement, since the 3D-printed button still absorps some of the light.
    The updated code, PCB files and 3D-printed files are available on GitHub in a separate branch, until I have done some more testing: https://github.com/CoretechR/Zicada/tree/boardrev3
  • Software
    Max.K • 11/16/2025 at 17:40 • 0 comments
    The nRF52840 is supported by Platformio, and inexpensive boards like the nice!nano can be programmed directly via their USB-port. I hoped that this would simplify software development, but there are two main issues: First, the nRF52 does not ship with a USB bootloader preinstalled, unlike the Raspberry Pi Pico. When using blank, factory-fresh chips, the only way to program them is through SWD. There’s not even a serial boot option by default.
    A second problem is Zigbee. Its protocol stack is proprietary and managed by the Connectivity Standards Alliance. Without paying licensing fees, manufacturers are not allowed to use the protocol or even mention “Zigbee“ in their branding. Vendors provide prebuilt Zigbee stacks, that function as black boxes. Nordic uses the ZBOSS Zigbee protocol stack as a precompiled library, which is only fully usable within the Nordic SDK. As a result, when developing my own Zigbee board, I was tied to Nordic’s SDK and needed an SWD/JTAG programmer load the software.
     There are several options for SWD debuggers, depending on the budget. The cheapest approach is buying a black pill STM32F4 board and flashing it with the Black Magic Probe (BMP) firmware. This turns the STM32 into a SWD debugger that can program the nRF52840. The BMP can then be selected as a debugger in VS Code. To support my board’s 2.2V logic, I added a level shifter to the STM32 board:
    While this was a working solution for basic flashing, I found it to be unreliable and inconvenient. I later bought a Segger J-Link mini for around 60€. It’s by far the cheapest fully-fledged JTAG debugger, provided you only use it for non-commercial projects. And although the documentation doesn't state it, the J-Link works perfectly fine with a 2.2V target. I also bought a super-cheap pogo pin clamp that uses the test pads on the back of my PCB, so I don't have to solder on connector to every single board.
    Now with a working way to flash the nRF52840, I began looking for a good starting point for my application. I had hoped that there were some official examples by Nordic, that I could base my code on. After all, a Zigbee temperature sensor is a very common type of device. But I had to realize that the latest version of the NRF Connect SDK (3.0.0) does not even include Zigbee support anymore. It requires a separate add-on which I could not get to work. Instead, I am using the slightly older version 2.6.0 with integrated Zigbee support. But even this version only comes with a small set of samples which demonstrate Zigbee communication between three Nordic evaluation boards. As a better starting point, I found Glen Akins Zigbee button project: https://bikerglen.com/blog/building-battery-powered-zigbee-buttons/
    This project already implemented many components that I needed for my sensor, most importantly a Zigbee cluster definition.
    Zigbee clusters are standardized sets of commands and attributes bundled together for specific device functions. This can be temperature, lighting, power consumption, etc. For my device, I had to combine the following clusters:
    • Basic: General device info like firmware version, manufacturer, and power source.
    • Identify: Lets the device identify itself, for example by flashing an LED.
    • Temperature Measurement: For reading temperature values, including tolerances and min/max limits.
    • Relative Humidity: Same as above but for humidity measurements
    • On/off: Stores a binary state, e.g. for door sensors or switches.
    • Power Configuration: Reports battery status.
    These clusters are defined in the Zigbee Cluster Library which ensure that Zigbee devices can communicate across different manufacturers. And it gets a little more complicated: Zigbee uses a client-server model, so for each cluster, you have to know if your device stores the information or the coordinator. What’s the coordinator? There are three types of Zigbee devices:
    • End devices: Typicall low-power nodes like sensors ...
  • Electronics
    Max.K • 11/16/2025 at 17:38 • 0 comments
    The main component of this project is the microcontroller which also has to serve as a Zigbee radio. Compared to Wi-Fi or Bluetooth, Zigbee support is less common in microcontrollers. Espressif offers the ESP32-C6, which seems like a good fit at first. However, due to its high power consumption in active mode and long boot-up time, it’s just not ideal for a battery-powered sensor. I like doing some rough calculations very early for battery powered projects like this. The math is straightforward: You always have a standby-mode current and an active-mode current. Then you factor in the time the device spends in each mode. Based on the battery capacity, you can then calculate an approximate battery life. This can be done quickly in Excel but Oregon Embedded’s online calculator is also very convenient:
    https://oregonembedded.com/batterycalc.htm
    Assuming 40mA during active mode and 3 seconds per measurement every 5 minutes, the ESP32-C6 would only run for around two months on a AAA cell. The standby current barely matters in this case as the device would waste the majority of its power during transmissions.
    Besides Espressif, various other manufacturers like Nordic, TI and Silicon Labs offer low-power MCUs designed specifically for Zigbee applications. Based on good availability, price, and the fact that you can obtain an evaluation board easily, I chose the Nordic nRF52840. It’s based on a Cortex-M4, has plenty of I/O and it includes a number of low-power optimizations, like an on-chip DC/DC converter and a switch for supplying external circuitry. Nordic specifies a standby current of 1.5 µA and a peak transmit current of under 5 mA. Doing the same calculations as before, yields a theoretical battery life of over 4 years. Of course, real-world factors like battery self-discharge will shorten this considerably. But it does look promising!
    One of my design goals was using a standard 1.6mm PCB. The nRF52840 uses quite a wild 7x7 mm QFN73 package with two rows of pins. Because of the density, not all of its pins are accessible without using plugged vias and a 4 layer PCB. This would not be an issue for this project since only few I/O pins are necessary - as long as none of the inaccessible pins need is essential. Unfortunately, one of these pins is the reset signal, which is quite important. I was almost considering switching to a different microcontroller before discovering Nordic’s nRF52840 Dongle, which also uses a low-cost 2-layer PCB. How did they solve this issue? I checked the design files and found that the reset-signal was simply routed through a few unused IO-pins. This seems a bit sloppy but if the manufacturer does it, so can I.
    The Dongle design also integrates a compact 2.4 GHz trace antenna that happenes to match the width of my board, so I used their antenna layout as a starting point. In general, there’s nothing unprofessional about copying antenna designs from evaluation boards. Nordic even recommends this specifically, since these are proven and certified designs.
    While most microcontrollers come with reference circuits from the manufacturer, Nordic provides a whole seven different circuit configurations for the nRF52840. These vary based on the power supply type and which features are enabled. Since I’m not using USB or NFC and have no use for the internal DC/DC converter, I chose configuration No. 6, which also happens to have the lowest part count. Nordic lists the 32.768 kHz clock crystal as optional, because the chip has an internal RTC crystal. But what is hidden a little deeper in the documentation is that using the external crystal reduces the power consumption by 1 µA vs using the internal one. I assume this is because the internal crystal needs more frequent calibration.
    The nRF52 support a wide supply-voltage range, but with a minimum of 1.7 V, it can’t be powered directly from a 0.9-1.2 V AAA cell. That calls for a step-up (boost) converter. I previously...
  • Hardware
    Max.K • 11/16/2025 at 17:36 • 0 comments
    In terms of design, smart home sensors are usually simple, unobtrusive devices and I wanted to keep it that way by using a white, 3D-printed case. Since the device can function as a contact sensor, it had to be small enough to be attached to a window or door frame. To figure out the necessary dimensions, I first searched for a suitable battery holder. Many common AAA holders consist of a plastic tray with two contacts, such as the Keystone 1020. However, since the case will be 3D-printed anyway, the whole plastic tray would take up unnecessary space. I ended up choosing the Keystone 56, which uses individual SMT-solderable spring contacts that add almost no length or height to the AAA cell. These sheet metal contacts are inexpensive and available from multiple manufacturers.
    With two of these contacts mounted to one side of a PCB, the other side could be fully used for the electronic components. This means that the overall size of the device is defined by the AAA cell, the battery holders and a standard 1.6mm PCB. There was just one more important consideration: the antenna. It needs to stick out from under the battery to work efficiently. To keep the cost and size down, I opted for a quarter-wave trace antenna which adds around 6 mm to the PCB length. The negative antenna terminal sits right next to the antenna and becomes part of the RF ground.
    The case mainly consists of two snap-fit shells that can be opened to replace the battery. Inside the front shell, there is another 3D-printed piece for holding the PCB in place and guiding the battery to its contacts. This inlay piece is also essential to ensure that the AAA cell can only be inserted the correct way. This is achieved by recessing the positive terminal slightly.
    Zigbee Devices require some mechanism to start the pairing process, so there is a hole in the case for a pushbutton. This button is attached to the case via a small hinge. By changing the filament mid-print, the button gains a transparent window to the status led beneath it.
    Another mini-version of the main device houses the magnets for contact sensing. I am using a set of six 2x5mm magnets, which seem to be strong enough to trigger the Hall effect switch.
    Both the sensor and the magnet case can be mounted to a window or door frame using double-sided tape. When it’s time to replace the battery, the main part of the case can simply be pulled off.
  • Instroduction
    Max.K • 11/16/2025 at 17:33 • 0 comments
    With open platforms like Home Assistant, smart homes have become quite popular over the past few years. I have accumulated some smart plugs, bulbs, and sensors myself, and I like Zigbee, because it supports low-power devices and decent ranges. One thing that always annoyed me was that most wireless sensors run on disposable coin cells. Even if they last for over a year, you always find yourself replacing batteries. Ikeas Parasoll contact sensor is one of the few devices powered by a (rechargeable) AAA battery but unfortunately it’s not free of design flaws. In general, there is a lack of open hardware or software among smart home sensors. I set out to change this by designing my own smart home device.
     I wanted to build a Zigbee sensor primarily for temperature and humidity measurements. And since most of the hardware is identical, I would also throw in a contact sensor. After all, this just meant adding a cheap hall effect switch to the device, so it can detect when a magnet is in proximity. My initial design goals were as follows:
    • The device should be powered by a single AAA cell like the Ikea Parasoll, so it needs to support voltages down to 0.9V.
    • Despite the small battery, it should have at least a full year of battery life.
    • It has to support smart home systems like Home Assistant and Zigbee2MQTT
    • The parts should be easy to obtain and the overall cost per sensor should be below 10€.
     Usually, I am cautious about investing too much time into a project before making certain that I can complete it. With a simple sensor like this, I was sure that the hardware side was manageable and the software could not be too complicated. After all, it just has to take measurements and send them to a Zigbee hub. That can’t be rocket science, can it? That was before I knew about things like Zigbee Clusters.
View all 5 project logs
