Very basic user interface
A project log for Alien Probes
A board series to help debug hardware at the lowest level
jacques-pelletierJacques Pelletier • 05/23/2026 at 03:49•0 Comments
The User Interface is done through a terminal (ANSI) with ANSI escape sequences. For now, the interface is rather basic but functional.
I had the opportunity to use them for debugging and it's rather cumbersome to use. Some could say cucumbersome!
Since I had these board working, I may make improvements to the UI for better use. I will put the code on Github.
