The MCU that I use for this series of boards is a STM32F405VGT6. It has ample room for controlling bits, and it can also run a software emulator for most of the 8-bit CPUs out there. The STM can support DMA and interrupts.
Supported CPUs so far:
Z80, Z8001, 8088, PC-XT, Generic, 6502, 6510, 6809
All these provide test features:
1) Bit control and probe to test for short, continuity, and other basic malfunction
2) Bus transaction to test peripheral (helps tame periferals to peripherals!)
3) Memory editing, IO manipulations
4) (Z80 for now) Emulation, stepping and register manipulation
Jacques Pelletier
Leon
Vitaly
Yes, I have 3 STM32 chips available and a 4th chip for the generic. Which ones do you need?
The 6809, 6502 and 6510 versions don't need patch, but the Z80, 8088, Z8001, PC XT and Generic need patches until I order new corrected version.
