IMG_20260817_050123101.jpgAssembled Alien Probes: 6502, 6510, 6809JPEG Image - 997.38 kB - 08/17/2026 at 09:03 |
6809.pngNew Alien Probe for 6809Portable Network Graphics (PNG) - 119.68 kB - 07/23/2026 at 17:56 |
6510.pngNew Alien Probe for 6510Portable Network Graphics (PNG) - 122.45 kB - 07/23/2026 at 17:55 |
6502.pngNew Alien Probe for 6502Portable Network Graphics (PNG) - 114.07 kB - 07/23/2026 at 17:54 |
6510-kicad.tar.bz26510 Alien Probex-bzip2 - 643.46 kB - 07/16/2026 at 05:16 |
6809-kicad.tar.bz26809 Alien Probex-bzip2 - 626.92 kB - 07/16/2026 at 05:16 |
6502-kicad.tar.bz26502 Alien Probex-bzip2 - 511.79 kB - 07/16/2026 at 05:16 |
Z80.pngFormer Z80-ICE2 is now an Alien Probe! Errors from Z80-ICE2 were corrected.Portable Network Graphics (PNG) - 114.00 kB - 05/23/2026 at 14:04 |
KiCAD-Z80.zipThe Z80-ICE2 is now part of the Alien probes! Like the others, files include: Schematic, PCB, GERBERs, BOM (ODS file), pdfZip Archive - 651.46 kB - 05/23/2026 at 14:00 |
KiCAD-Leadframes.zipLeadframe PCBs for 48-pin, 40-pin, 32-pin and 28-pin DIPs. It adapts a DIP chip to a standard header either male or female. The lead frames can be bought on ebay here: https://www.ebay.ca/itm/296681581555To solder the lead frame, it's best to cut the strip to length; i.e. for a 40-pin module, cut 2 20-pin strips. Leave them all attached and cut the frame holders after soldering. Zip Archive - 173.71 kB - 05/23/2026 at 05:34 |
KiCAD-8088.zipThis is version 2 of the PCB, correcting errors from previous version.All KiCAD files to generate the PCB. Includes: Schematic, PCB, GERBERs, BOM (ODS file), pdf Zip Archive - 1.10 MB - 05/23/2026 at 05:19 |
KiCAD-Generic.zipThis is version 2 of the PCB, correcting errors from previous version.All KiCAD files to generate the PCB. Includes: Schematic, PCB, GERBERs, BOM (ODS file), pdf Zip Archive - 1.16 MB - 05/23/2026 at 03:39 |
KiCAD-PCXT.zipThis is version 2 of the PCB, correcting errors from previous version.All KiCAD files to generate the PCB. Includes: Schematic, PCB, GERBERs, BOM (ODS file), pdf Includes the drawing for the USB hole in the PC bracket. Zip Archive - 1.24 MB - 05/18/2026 at 22:33 |
Capture d’écran du 2026-05-16 08-12-29.pngZ8001 firmware in the Bit Test Menu (added a bit of color)Portable Network Graphics (PNG) - 77.62 kB - 05/16/2026 at 12:50 |
Capture d’écran du 2026-05-16 08-12-20.pngGeneric Alien Probe with the 'Probe only' firmwarePortable Network Graphics (PNG) - 27.05 kB - 05/16/2026 at 12:48 |
GenericProbeOnly.tar.bz2Firmware for the Generic Alien Probe. It acts only like a probe. It displays inputs from 16-bit Ports B,C,D,E,F,G continuously (updated each 100ms).Use minicom on Linux or Teraterm/Putty/etc. on Windows and connect to the USB serial port. IDE is: STMCube IDE Version: 1.19.0 Build: 25607_20250703_0907 (UTC) To upload, I use a common ST-LINK V2 available everywhere. x-bzip2 - 7.20 MB - 05/16/2026 at 12:39 |
KiCAD-Z8001.zipThis is version 2 of the PCB, correcting errors from previous version.All KiCAD files to generate the PCB. Includes: Schematic, PCB, GERBERs, BOM (ODS file), pdf Zip Archive - 1.01 MB - 05/15/2026 at 20:35 |
IMG_20260512_095341614.jpgGeneric Alien ProbeFirmware ready JPEG Image - 3.43 MB - 05/12/2026 at 14:11 |
IMG_20260512_095527526.jpgZ80 ICE2 emulates a Z80, also an Alien ProbeFirmware ready JPEG Image - 1013.92 kB - 05/12/2026 at 14:11 |
IMG_20260512_095544766.jpg8088 Alien Probe (firmware to be completed)JPEG Image - 1004.68 kB - 05/12/2026 at 14:11 |
IMG_20260512_095316261.jpgZ8001 Alien probeFirmware under way JPEG Image - 1.02 MB - 05/12/2026 at 14:11 |
IMG_20260512_095646201.jpgPC-XT Alien ProbeFirmware ready JPEG Image - 918.72 kB - 05/12/2026 at 14:11 |
IMG_20260512_094948979.jpgSetup for debugging the Z8001 AP with the Generic Alien ProbeJPEG Image - 983.66 kB - 05/12/2026 at 14:11 |
IMG_20260512_095722734.jpgCrystal modification. Will be implemented with other modifs in the upcoming version.JPEG Image - 899.00 kB - 05/12/2026 at 14:11 |
Jacques Pelletier
