ESP32 NTP Clock
A Clock that sets itself over WiFi
Starting from
has orders / reviews
Ships from
First there was my GPS clock. Then, for situations where GPS reception wasn't easy or possible, I made a Raspberry Pi Zero clock. But the Pi is a bit overkill. The middle ground is this project: A clock display driven by an ESP32 that fetches time via NTP over WiFi.
Going back to the first iterations of the GPS clock, the display is managed by a MAX6951. The SPI pins are connected up to the default SPI interface pins of an ESP32-C3-MINI-1 (pin 0 CLK, pin 3 DIN, pin 10 !CS). The boot selector pin (pin 9) goes to a solder jumper. To place the ESP32 in the sketch upload mode, you short that jumper out while applying power (I find a piece of solder wick braid best for this. Just hold it on the pads while plugging it in). The barrel connector for power has been replaced with a USB-C socket. This allows the same connector to be used for firmware updates as well as normal power. The only other addition is a single button that goes to pin 4. This button puts the clock in the setup mode.
On the firmware side, I needed to find a high-precision NTP client implementation. The ones that sort of come with Arduino are only good to the second and I wanted to display tenths and for them to be reasonably accurate. There is, of course, NTP built-in to the ESP32 firmware, but the problem with that is that there is no fix quality feedback mechanism, and I want to stop displaying time rather than let a drifting time get displayed. To do that, I turned to the ESPNtpClient library. But that library has a crash bug in it, so I found this fork that works properly. You'll want to install that version in your IDE if you want to build the firmware yourself.
When the clock boots up, it uses the preferences API to load the WiFi, NTP and feature configuration. The clock will show a brief LED test and then show "no ntP" until the clock is synchronized with the NTP pool.
At any time, you can push the setup button. The display will show "SEtuP" and the board will go into WiFi AP mode with the SSID "ESPClock". Once connected, open a web browser and you should find a captive portal that will redirect you to a setup UI where you can put in the correct WiFi SSID and password (WPA2 and WPA3 personal are supported), override the default NTP server if you wish, change the display brightness, set 12 or 24 hour mode, enable or disable the tenth of a second digit, set the mode for the colons (off, on or blink) and select your time zone (or enter your own time zone string). Once you submit that page, the preferences will be updated and the clock rebooted.
ESP32_Clock_Latest.bin
Latest firmware - for OTA firmware update
macbinary - 1.08 MB - 06/15/2026 at 18:47
Download
esp_clock_1_2.pdf
Adobe Portable Document Format - 56.24 kB - 12/23/2025 at 16:29
Preview
esp_clock_1_2.brd
brd - 117.00 kB - 12/23/2025 at 16:27
Download
esp_clock_1_2.sch
sch - 207.02 kB - 12/23/2025 at 16:27
Download
  • OTA firmware updates
    Nick Sayer06/15/2026 at 18:58 0 comments
    I've figured out a way to support firmware updates over WiFi. It's not trivial, but it's possible.
    To do this, you have to make a custom partition map for the flash. This partition map needs:
    • A space at 0 for the bootloader
    • A space for NVS for saving preferences
    • A small space for the bootloader to look for which partition to jump into
    • The main partition for the running code
    • A smaller (384K) partition to contain an update executable
    • 2M for SPIFFS - We use that as a staging space
    If you look in the git repo now there are two sketches and two custom partition maps. To make this work with Arduino, you need to compile the two as separate sketches. The partition maps are the same except that each has the main and auxiliary code partition slices swapped. The result is that the small updater sketch is compiled for the space at 0x1A0000 and the main code is compiled for the usual location of 0x10000.
    To initialize a new board, it's enough to write the "merged.bin" from the main sketch at 0x0, then the ".bin" from the updater sketch at 0x1A0000.
    To use it, push 'setup,' then in the captive portal page, there's a new firmware update form at the bottom. Select the firmware bundle file and upload it. The main code will authenticate the bundle, then jump into the updater code, which will update the main code space and then reboot.
    The format of the file is special: It starts with a 4 byte magic number, then a 2 byte version/flags word that is zero currently and TBD. Next is a 2 byte "digest length" (always 32), and then a SHA-256 computed over the entire file except for the digest length and digest fields.
    Next after the digest is a single byte "chunk count." Then come the chunks. Each chunk is a 4 byte start address, a 4 byte length, and then the data.
    All of the 2 and 4 byte values are in network byte order.
    This should allow updating anything except for the SPIFFS and the updater itself. Either of those would require updating via USB.
    This also requires a change of the board type from SparkFun Pro Micro to "ESP32C3 Dev".
    Of course, you have to update the whole thing over USB one last time before this will work.
  • First build report
    Nick Sayer12/09/2025 at 01:11 0 comments
    The boards from OSHPark came back and they work just fine. Shorting the boot pads while applying power puts it into the firmware loading mode as expected and the firmware worked the same as it did on the prototype.
    Moreover, the board fits just fine in the 3D printed case. That was simply a modified version of the GPS clock case, with some of the lettering changed, one of the button holes removed, the antenna hole removed and the power hole elongated to accommodate a USB-C jack.
    I am going to order a v1.1 board. It will move the ESP closer to the USB jack just to cut down on the trace lengths and replace the TVS diode with a USB protection diode array that protects the data lines as well as the VUSB. When that comes back and is tested I'll probably get some assembled and add them to the store.
  • Config web UI & accuracy checks
    Nick Sayer11/20/2025 at 21:39 0 comments
    I was able to figure out how to do the configuration UI. Pressing the "setup" button will display "SEtuP" on the display and create a WiFi network called "ESPClock". Connect to that and then surf to the web page at 192.168.4.1 and you'll get a form to put in the SSID, password, hostname NTP server and set things like 12/24 hour mode, enabling or disabling the 10th of a second digit and setting the mode for the colons.
    I was also able to perform a rudimentary accuracy check on the clock. I took some slow-motion videos of the ESP clock prototype next to one of my GPS clocks. The iPhone slo-mo video seems to me to be running at about 120 FPS or so, so any given frame is maybe 8 ms or so away from its neighbor. Immediately after startup, the two clocks were changing the tenth-of-a-second digit about 6 frames apart, which is not great, but after sitting for an hour the two clocks were changing in perfect unison. Even at the start they were within 50 ms of each other, so that's still not too much to complain about. I'm certainly confident that it'll be just as accurate or more than the Pi clock I used to have.
  • Prototype results
    Nick Sayer11/20/2025 at 18:02 0 comments
    The prototype is up and running. It consists of the Pi clock display board with the Pi removed and a SparkFun Pro Micro ESP32-C3 hooked up to it with 5 jumper wires. The wires cary the 3 lines of the SPI interface (MISO is not used), ground and +5. This setup has allowed me to develop the firmware and validate the design (at least as much as possible).
    At the moment, the bit still missing is the setup system, which puts the WiFi into AP mode and puts up a web server. That's still TBD. But everything else is working, and that's good enough to move on to dedicated hardware.
    The first board has been ordered from OSHPark as well as raw C3-Micro modules from DigiKey and a paste stencil for the modules. Fingers crossed for the first build!
View all 4 project logs
