Hackaday.io Hackaday.io
Sign up Log in
SD Card Over Wi-Fi
A simple ESP32 wireless file access system for SD cards. Ideal when USB data ports are damaged, blocked, or unsupported.
rishabrishab
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
0 comments
3 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
Public Chat
325
0
3
4
Team (1)
  • rishabrishab
Join this project's team
Software
ongoing project
This project was created on 11/30/2025 and last updated 9 months ago.
Description
This project is a compact ESP32-based wireless SD card interface designed for situations where traditional USB data transfer isn’t possible or supported. The device doesn’t use USB for data — only for power. Instead, it exposes the SD card over Wi-Fi so files can be accessed through any standard web browser.
This becomes useful in scenarios like locked or restricted systems, devices with damaged USB data pins, phones without OTG support. With the ESP32 running the interface, the SD-MMC bus operates in 4-bit mode for improved performance, reaching speeds of up to ~500 kbps in practical use
No drivers, apps, or special software are required — if a device has a browser, it can read, write, rename, upload, delete, and manage files wirelessly on the SD card.
Full demo video ▶ https://youtu.be/SbW0ZwTfWdI
Details
Log In/Sign up to comment
Sign up with Github
OR
The 2015 Hackaday Prize
Stuck on a island in the middle of the ocean without a wifi backup disk? The TEENSY SD USB back up tool is what you need!
Project Owner Contributor
SD card back up tool
enricoEnrico
Maybe the best way to Multicomp
MultiComp FPGA Card
land-boardscomland-boards.com
Attiny85-based device to enable and disable write-protection on any SD card.
sdlocker-tiny
nephielNephiel
The 2017 Hackaday Prize
This card has not-protected NFC tags, that can be programmed to do actions, or save data. They can also be protected with a password.
NFC Card
sagi-harushSagi Harush
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "SD Card Over Wi-Fi", please tell us the reason.
Send message
Remove Member
