Right now my Lunar Lander looks a lot like Spacewar! and Computer Space, a ship flying around in the blackness of space. What makes Lunar Lander unique is the moonscape at the bottom of that screen. One might say that Lunar Lander is more grounded as a result.
I use the term "moonscape" loosely. In the original, the ground is just a 2D low detail representation of some hilly terrain drawn using vector graphics as a single solid line. Never the less the way that line smoothly transitions as it changes direction "feels" like the land it represents.
On the PDP-1, I do not have the pixel "budget" to draw a curvy solid line from the left to the right side of the screen. That would be over a thousand pixels. At most the PDP-1 is only capable of refreshing a few hundred pixels each frame. Since the terrain is an important part of the game I think a hundred pixels is a reasonable allocation for drawing it.
So generate some "realistic" looking terrain using only a hundred pixels. No Problem.
Actually it turns out there is a LOT of information on generating 2D and 3D terrain, mostly coming out of the gaming community. There are a number of techniques for taking some height samples and smoothing them into something that mimics "land" to the eye. One of these is cosine interpolation.
Cosine interpolation is a smooth, curved method for estimating values between two points, using a portion of a cosine wave to create a natural-looking transition. It is often used to generate more aesthetically pleasing curves for periodic or oscillating data.
I was lucky enough to find a Python script that was exactly tailored to my needs. I spent considerable time trying to re-locate the source so that I could credit them, but was unsuccessful. So to the author: Thank you so much.
import numpy as np
import matplotlib.pyplot as plt
def cosine_interpolation(y1, y2, mu):
Performs cosine interpolation between two points.
Args:
y1 (float): The value of the first point.
y2 (float): The value of the second point.
mu (float): The interpolation factor (0.0 to 1.0) indicating the
relative distance between the points.
Returns:
float: The interpolated value.
mu2 = (1 - np.cos(mu * np.pi)) / 2
return y1 * (1 - mu2) + y2 * mu2
def smooth_terrain_with_cosine(data, num_new_points):
Smooths 1D terrain data by interpolating new points between existing ones
using cosine interpolation.
Args:
data (np.array): The original 1D terrain data.
num_new_points (int): The total number of points desired in the smoothed data.
Returns:
np.array: The new, smoothed terrain data.
# Original data points indices
x_old = np.linspace(0, 1, len(data))
# New points indices
x_new = np.linspace(0, 1, num_new_points)
y_new = np.zeros(num_new_points)
# Calculate the number of original data points
n_original = len(data)
for i, x_val in enumerate(x_new):
# Find the two nearest original data points
# np.searchsorted finds the index where x_val would be inserted to maintain order
idx_right = np.searchsorted(x_old, x_val, side='right')
# Handle boundary cases for the last point
if idx_right == n_original:
y_new[i] = data[-1]
continue
idx_left = idx_right - 1
# Get the y values of the surrounding points
y1 = data[idx_left]
y2 = data[idx_right]
x1 = x_old[idx_left]
x2 = x_old[idx_right]
# Calculate the interpolation factor (mu)
mu = (x_val - x1) / (x2 - x1)
# Perform cosine interpolation
y_new[i] = cosine_interpolation(y1, y2, mu)
return y_new
# --- Example Usage ---
# 1. Generate some sample terrain data (e.g., random heights at fixed intervals)
original_data = [400, 240, 240, 100, 30, 30, 70, 70, 40, 40, 40, 40, 80, 120, 160, 160, 240, 320, 360,360]
# 2. Define the desired total number of points for the smoothed terrain
smoothed_points_count = 100
# 3. Smooth the data
smoothed_data = smooth_terrain_with_cosine(original_data, smoothed_points_count)
#print(smoothed_data)
# 4. Plot the results
plt.figure(figsize=(10, 6))
plt.plot(np.linspace(0, 1, smoothed_points_count), smoothed_data, label='Cosine Smoothed Terrain', color='blue')
plt.scatter(np.linspace(0, 1, len(original_data)), original_data, color='red', zorder=5, label='Original Data Points')
plt.title('1D Terrain Smoothing using Cosine Interpolation')
plt.xlabel('Normalized Distance')
plt.ylabel('Height')
plt.legend()
plt.grid(True, linestyle='--', alpha=0.6)
plt.show()
# 5. Convert the data into x,y coordinates that lunar lander can use.
# Coordinates will be put into 18 bits with x occupying the upper
# 9 bits and y the lower nine bits.
x = 0
count = 0
for y in smoothed_data:
# Convert the coordinates to PDP-1 screen space.
sx = x - 511
if sx < 0:
sx = abs(sx) ^ 0b1111111111
sy = int(y) - 511
if sy < 0:
sy = abs(sy) ^ 0b1111111111
# Drop the least significant bit of each coordinate and pack into 18 bits.
xy = ((sx>>1)<<9)+(sy>>1)
print(count, str(x-511).zfill(3),str(int(y)-511).zfill(3),bin(sx),bin(sy),bin(xy)[2:].zfill(18),'\t\t',oct(xy)[2:].zfill(6))
x = x + 10
count = count + 1
print("y-coordinates")
count = 0
print(count,str(int(y)).zfill(3),'\t\t',oct(int(y))[2:].zfill(6))
count = count+1
All I had to do was:
- Add my terrain data in original_data. I entered 20 height values into the array that defined the general shape that I wanted the "ground" to be.
- Set smoothed_points_count to be 100, the number of points I wanted.
- Add code (#5) to take the generated data and convert the points to screen coordinates in a format that would be efficient to plot. I borrowed this idea from ICSS where coordinates are put into an 18 bit word with x occupying the upper 9 bits and y the lower nine bits and the least significant bit assumed to be 0.
That's it. When I ran the script it emitted a plot of what it had done.
It's elongated in the vertical direction but totally what I was looking for. Then here are my 100 terrain points in octal format ready to drop into the lunar lander code.
trn, 400710
405700
412656
417626
424602
431570
436570
443570
450570
455570
462570
467565
474551
501525
506501
513464
520461
525454
532442
537430
544421
551416
556417
563417
570417
575417
602417
607420
614425
621433
626440
633442
640443
645443
652443
657443
664443
671442
676440
703433
710427
715424
722424
727423
734424
741424
746424
753424
760424
765424
772424
777424
004424
011424
016424
023424
030424
035424
042424
047430
054436
061444
066447
073450
100453
105461
112467
117473
124474
131476
136503
143511
150516
155517
162520
167520
174520
201520
206520
213522
220533
225546
232561
237567
244571
251600
256614
263627
270636
275640
302643
307650
314656
321662
326664
333663
340664
345664
352664
357664
And finally I added the code to plot the terrain.
/ Draw the terrain.
init dti, trn / Point to first word of terrain data.
jsp dtr / Draw the terrain.
dtx, jmp .
dtr, dap dtx
dti, lac . / Get the next terrain data word.
sza i / Is 0?
jmp dtx / Yes - return.
cli / Set the y coordinate.
scr 9s / Shift low 9-bits into the high 9-bits of IO.
sal 9s / Move remaining 9-bits into the high part of AC.
dpy-i 4300 / Plot the point.
idx dti / Bump the data address to the next point.
jmp dti / Continue.
And with that my blogging has caught up with where I actually am in program development. Here is the What I Have So Far video again.
Michael Gardi
