Perfect — that slogan is exactly right, and it’s bold in the right way.
Below is a surgically revised README that centers the slogan “Moth is Sublime.” as the thesis, while staying technically credible and clearly clean-room compatible (Linux/UNIX model).
This version is confident, memorable, and will absolutely get the attention of the Sublime / systems crowd.
🦋 Moth-Text
Moth is Sublime.
Moth-Text is a from-scratch, open-source reimplementation of Sublime Text, written entirely in Swift and powered by a custom UI engine called Luna-UI.
Like Linux in relation to UNIX, Moth is not Sublime Text — but it is Sublime in behavior, compatibility, and philosophy.
Moth is Sublime. Same ideas. Same workflows. Same power. Clean-room implementation. Modern internals. Open future.
🎯 What “Moth is Sublime” Means
“Moth is Sublime” is not a slogan about imitation — it’s a statement of compatibility by design.
| Moth-Text |
| Open-source implementation |
| Swift / Python |
| Luna-UI |
| Plugin-driven |
| UNIX-style architecture |
Just as:
Linux is UNIX-compatible without being UNIX
So:
Moth is Sublime without being Sublime Text
🎯 Project Goals
- Full Sublime-compatible behavior
- Native performance on macOS and Linux
- Long-term API and plugin stability
- Clean separation of UI, editor core, and plugins
- No dependency on web tech or heavyweight UI frameworks
❌ What Moth-Text Is Not
- Not a fork of Sublime Text
- Not a re-skin or clone UI
- Not Electron
- Not SwiftUI, GTK, or Qt
- Not a web editor in disguise
This is a clean-room reimplementation, built to last decades.
🧩 Sublime Compatibility Targets
Moth-Text is being built to match Sublime’s behavior and ecosystem, including:
✔ Editor Semantics
- Identical selection and multi-cursor model
- Same command-driven architecture
- Same keybinding resolution logic
- Same editing edge cases and behaviors
✔ Package & Plugin System
- Python 3 plugin runtime
- Sublime-style package layout
- Command registration
- Event hooks
- View / window APIs
- LSP integration
The long-term goal is that most Sublime packages can be ported with little or no modification, and many will work unchanged.
🧠 Architecture Overview
Moth-Text intentionally mirrors Sublime’s proven architecture, while modernizing the internals:
┌─────────────────────────────┐ │ Moth-Text App │ │ │ │ ┌──────── Luna-UI ──────┐ │ │ │ Windowing │ │ │ │ Rendering (GPU/CPU) │ │ │ │ Input │ │ │ │ Text Shaping │ │ │ └──────────────────────┘ │ │ │ │ ┌────── Editor Core ────┐ │ │ │ Buffers │ │ │ │ Views │ │ │ │ Commands │ │ │ │ Selections │ │ │ └──────────────────────┘ │ │ │ │ IPC (Unix domain sockets) │ │ │ │ ┌────── Plugin Host ─────┐ │ │ │ Python Runtime │ │ │ │ Packages │ │ │ │ LSP / Tools │ │ │ └───────────────────────┘ │ └─────────────────────────────┘
This enables:
- Plugin isolation
- Crash resistance
- Hot-reloadable extensions
- Stable long-term APIs
🌙 Luna-UI — Why Moth Can Be Sublime
Luna-UI is the reason this project exists at all.
What Luna-UI Is
A from-scratch, cross-platform UI and rendering engine, written in Swift, designed specifically for editor-class applications.
It provides:
- Native window creation (macOS + Linux)
- GPU-accelerated rendering (CPU fallback)
- Deterministic input handling
- Pixel-perfect custom widgets
- Exact text metrics and cursor positioning
- First-class support for:
- Ligatures
- Complex scripts
- High-DPI rendering
Why Not Use Existing UI Toolkits?
General UI frameworks optimize for:
- Forms
- Buttons
- Dialogs
Editors need:
- Absolute control over text
- Predictable timing
- Zero layout surprises
- Maximum performance
Sublime solved this with a custom engine. Moth does the same — openly — with Luna-UI.
🧪 Project Status & Roadmap
✅ Phase 0 — Foundation (Complete)
- Swift toolchain validated on Linux and macOS
- Unix domain socket IPC
- JSON-based protocol
- Separate plugin host process
✅ Phase 0b — Persistent Runtime (Complete)
- Long-running...
AVR
sbi.gaijin
Steve Hernandez
David Effendi
