What is does
Scan an item and have it added to your Home Assistant shopping list.
How it does it
Using Home Assistant
- You can scan directly from Home Assistant in the web or via the Home Assistant Companion app and use your device camera to add an item to your BeepBasket list. ( You do need HTTPS for your camera to work )
- From the list you can add it by the click of a button to your Shopping list in Home Assistant.
- Product lookups are done using the Open Food Facts API.
- If the Item is unknown, It will display the barcode in your shopping list.
- When you update a barcode inside your BeepBasket card, it will remember the change for the next time you scan that barcode again.
Going pure hardware
- Here we have a off-the-shelf budget friendly barcode scanner.
- The scanner will read the barcode, and immediately put the item in your BeepBasket as well as in your shopping list.
- With a barcode scanner next to the dustbin, when something is finished, before you throw it away, you just scan it and its directly added to you shopping list.
Installing on HACS
There are 2 packages the needs to be installed. The integration and the Card.
The integration
Go to your HACS installation and select custom repositories
Add the custom repository to https://github.com/meijerwynand/beepbasket and set the type to Integration
You will see it listed in the window
In HACS then download the repo
Go to you Settings -> Devices and integration -> Add integration and search for BeepBasket
I will then ask you to associate your shopping list
And you are done
Restart your Home Assistant
The card
Follow the same step again in hacks, this time select the https://github.com/meijerwynand/beepbasket-card with type of Dashboard.
Follow the same download steps as before/
Now you can add the BeepBasket as a manual card
Use the
type: "custom:beepbasket-card"
Alex
NaranInc
