1Getting the parts
2Wiring the scanner
VCC -> 12v (since this scanner is USB power, you can supply it VCC from the ESP32) GND -> GND TTL-TX -> GPIO16 TTL-RX -> GPIO17![]()
3Flashing the ESP
This is the most important, the rest you can keep to your own ESPHome flavoring
logger: level: INFO # Clean logs uart: id: r35c tx_pin: GPIO17 rx_pin: GPIO16 baud_rate: 57600 parity: NONE # Global storage for HA globals: - id: barcode_buffer type: std::string initial_value: '""' - id: last_scan_time type: uint32_t initial_value: '0' interval: - interval: 500ms then: - lambda: |- static char buf[64]; static int pos = 0; static uint32_t clear_time = 0; uint8_t byte; while (id(r35c).available()) { if (!id(r35c).read_byte(&byte)) break; if (byte == '\r' || byte == '\n') { if (pos > 0) { buf[pos] = '\0'; if (millis() - id(last_scan_time) > 1000) { id(barcode_buffer) = std::string(buf, pos); id(dustbin_barcode).publish_state(id(barcode_buffer)); ESP_LOGI("BARCODE", "Dustbin: '%s'", buf); id(last_scan_time) = millis(); clear_time = millis() + 3000; // Clear in 3s } pos = 0; } break; } if (pos < 63) buf[pos++] = byte; } // Clear buffer after 3s delay if (clear_time > 0 && millis() > clear_time && id(barcode_buffer).length() > 0) { id(barcode_buffer) = ""; id(dustbin_barcode).publish_state(""); clear_time = 0; ESP_LOGI("BARCODE", "Buffer cleared"); } text_sensor: - platform: template name: "Dustbin Barcode" id: dustbin_barcode lambda: |- return id(barcode_buffer); update_interval: never -
4Program the scanner
This given scanner was programmed using QR codes that came with device. Most important in setting the device to output on TTL/Serial RS232 and the appropriate baud rate
- Factory reset
- Set Serial port TTL and RS232
- Set baud rate to 57600
5Assemble and install
