Software Architecture v5.0
A project log for A learning VOC Filter for the lab
A VOC filter that adapts to your space. Dual SGP30 sensors, baseline tracking, drift compensation, and filter health prediction on ESP32-C6.
apollo-timbersApollo Timbers 01/03/2026 at 21:050 Comments
Software Architecture (how I actually built it)
Three-module setup... clean, simple, and it does what it needs to do:
1) Main Firmware (the “keep the thing alive” brain)
This handles the display, BLE stack, fan control, button input, and sensor polling.
The UI cycles through four pages: main readings, filter status, environment, and a scrolling diagnostics page where I can literally watch what the adaptive system is thinking in real time.
2) Adaptive Sensor Module (the “learning” part)
This is where the system gets smarter instead of just spitting out raw numbers.
3) Event & Filter Module (the “what does this mean?” part)
This tracks what’s happening in the real world and turns it into useful outputs:
Gotchas & Lessons Learned (aka: why the first version lied to me)
Efficiency math is way harder than it looks.
My first pass was the obvious approach: inlet vs outlet. Super clean. Totally wrong.
Because if your room baseline is already garbage (or already clean), the raw ratio is misleading. Once I accounted for baseline air quality and what’s realistically removable, the numbers started matching real filter performance.
Sensors drift. Hard.
VOC sensors don’t “measure truth.” They measure vibes.
They can get stuck reporting the wrong value for hours like they’re gaslighting you. So I added drift detection + compensation logic instead of trusting raw readings.
Calibration isn’t optional.
Two “identical” sensors won’t read the same in identical air. Ever.
So the system has to learn the offset between the pair, or you’re just building a fancy random number generator.
Persistence matters.
All learned parameters save to non-volatile memory so it doesn’t forget everything after a power cut.
But you can’t write constantly or you’ll wear out flash/EEPROM… and you can’t write too rarely or you lose learning when power drops at the worst time. So yeah, balancing save frequency was a whole thing.
Current Feature List (what it can do right now)
