Materials:
-Brass bar stock - https://amzn.to/49AbpiT
-Mother of pearl - https://amzn.to/3NoCsWU
-Delrin - https://amzn.to/4qOz1Y3
Tools:
-Two-part epoxy - https://amzn.to/4sDIsv2
-E6000 - https://amzn.to/4jIwFrw
-Hot glue - https://amzn.to/4552jcG
-Sand paper - https://amzn.to/3NoH6UQ
-Cotton buffing wheel - https://amzn.to/3LCsl02
-Polishing compound - https://amzn.to/3ZakfyY
Key things I learned:
- Pearl dust is hazardous - use a respirator and spray water to keep dust down
- Hot glue works for holding irregular objections on a shaft. Heat the shaft with torch and apply glue.
- Make a quick spline adapter by machining Delrin a few thousandths under your male spline, and press into place
Franklinstein
mosaicmerc
vincentmakes
Steve Hernandez
cool, I cant really see how you machined the inside of the brass to clip onto the part of the psu though. Did you drill a hole and then put a ring od delrin in. Ps whats delrin? Is it flexible somehow.
My challenge is that the stick part in my rotary encoder is like a half circle D shape and I cant make that shape inside a piece of brass/steel. How does one do that?
