I printed a couple of bearing holders.
Next, I printed an axle/wheel attachment. This also connects to the motor.
I drilled 3 holes through the plastic wheel and attached the axle to the wheel.
Next, I soldered wires to the motor.
This was followed by attaching the gear shaft to the axle assembly.
The motors/wheels were mounted to the plexiglass with 3mm screws.
Mike Rigsby
