chrono-ntp
Minimal terminal clock synced to NTP. Exploring alternative time sources (GPS) and formats (LTC, MTC, Swatch Internet Time).
0 followers
chrono-ntp is a minimalist, cross-platform terminal clock that synchronizes directly with an NTP server to display accurate time, independent of the system clock.
It continuously measures and applies the offset to an NTP source and shows a live-updating date and time in the terminal. chrono-ntp is intended as a clean reference clock for tasks like setting mechanical or digital watches or running a distraction-free terminal clock.
Key Features
  • Cross-platform: Linux, macOS, and Windows support (x86_64 and ARM)
  • NTP-synchronized time with automatic offset refresh
  • Multiple time formats, including ISO 8601, 12-hour, Unix, Swatch Internet Time (.beat), septimal time, Coordinated Mars Time (MTC), and Coordinated Lunar Time (LTC)
  • Time zone support with optional display
  • Optional Greenwich Time Signal beeps
  • Available as prebuilt binaries or via Homebrew
  • Adding GPS/NMEA as a Time Source
    Christian7 hours ago 0 comments
    chrono-ntp currently uses NTP servers to determine an accurate time offset independent of the local system clock. While this works well on networked systems, the next step is to support GPS as an alternative time source.
    Many USB GPS receivers expose a serial interface and provide NMEA sentences, including time and date information derived from GPS signals. Using GPS would allow chrono-ntp to operate as a network-independent reference clock, useful in environments without reliable internet access or where an external time source is preferred.
    The plan:
    • Read NMEA data from a serial device (USB GPS receiver)
    • Extract time information from standard sentences (e.g. RMC, ZDA)
    At the moment, I’m looking for a suitable USB GPS receiver to test this with real hardware rather than relying solely on simulated NMEA data. Once a device is selected, initial work will focus on basic parsing and validation before integrating it cleanly into chrono-ntp’s existing architecture.
    This should keep the tool simple while expanding it beyond network-based time synchronization.
View project log
Ken Yap wrote 4 hours ago point
Aren't modern OSes already running a system service to sync the system clocks to NTP and other sources? For example Linux runs chronyd or the older ntpd. Chronyd can also interface to a GPS receiver using gpsd. See #An NTP server using GNSS for time So to get the NTP time, just show the system time.
