See http://blog.deckerego.net/search/label/garage%20door for detailed background on how this project was tested and initially constructed. The build instructions at Hackaday Projects should walk you through the hardware setup, and the README within the GitHub repository should walk you through the software setup.
DeckerEgo
NaranInc
Benjamin Blundell
jason.gullickson
