Papaya Pathfinder
Papaya Pathfinder is an open-source family of small remote-controlled rovers based on the ESP32.
The project currently includes two rover variants, designed for different sizes, motors, and power requirements.
All mechanical parts of the rovers are fully 3D-printable, and all models are available in the 3d-models/ directories of each rover variant.
The rovers can be operated using either WiFi or ExpressLRS (ELRS), depending on the firmware configuration.
Papaya Pathfinder
- ESP32
- ELRS receiver (required only when running
firmware-elrs) - 6× GA25 DC gear motors
- 4× MS24 steering servos
- Power supply: LiPo 3S
Firmware
The rover supports multiple firmware configurations, each enabling a different communication method.
firmware-wifi- WiFi-based control
- HTTP API for movement commands
- Compatible controllers:
- Python desktop controller — sends gamepad-based control commands to the rover via HTTP.
- Android mobile app — enables rover control using a gamepad, providing the same driving experience available on the desktop controller.
firmware-elrs- Control via ExpressLRS (ELRS)
3D-Printed Parts
All STL files for this rover are available in: pathfinder/3d-models/
The complete mechanical design is also available in STEP format: pathfinder/cad/papaya-pathfinder.step
Use PETG or PLA for the structural parts, and TPU for the tires. All parts are designed to be assembled using M3 screws and nuts.
| File | Qty | Material | Notes |
body.stl |
1 | PETG / PLA | Main chassis |
arm_left.stl |
1 | PETG / PLA | Left suspension arm |
arm_right.stl |
1 | PETG / PLA | Right suspension arm |
pivot_left.stl |
1 | PETG / PLA | Left pivot mount |
pivot_right.stl |
1 | PETG / PLA | Right pivot mount |
differential_bar.stl |
1 | PETG / PLA | Central rocker-bogie differential bar |
differential_link_left.stl |
1 | PETG / PLA | Left link between differential bar and suspension arm |
differential_link_right.stl |
1 | PETG / PLA | Right link between differential bar and suspension arm |
motor_mount.stl |
4 | PETG / PLA | Motor mounts for GA25 motors used on steering arms |
horn_adapter.stl |
4 | PETG / PLA | Servo horn adapters for steering servos. Print horizontally for strength. |
rim.stl |
6 | PETG / PLA | Wheel rims |
tire.stl |
6 | TPU | Tires |
Papaya Pathfinder Mini
- ESP32 with camera (ESP32-CAM / ESP32-S3-CAM) (required only when running
firmware-wifi) - ELRS receiver (required only when running
firmware-elrs) - 6× N20 DC gear motors
- Power supply: LiPo 2S
Firmware
- Live video streaming over WiFi
- Python desktop controller — displays the live video stream and sends gamepad-based control commands to the rover via HTTP.
- Android mobile app — displays the live video stream and enables rover control using a gamepad, providing the same driving experience available on the desktop controller.
3D-Printed Parts
All STL files for this rover are available in: pathfinder-mini/3d-models/
The complete mechanical design is also available in STEP format: pathfinder-mini/cad/papaya-pathfinder-mini.step
body.stl |
arm_left.stl |
arm_right.stl |
pivot_left.stl |
pivot_right.stl |
1 | PETG / PLA | Central differential bar for the rocker-bogie suspension |
differential_link.stl... |
Sergio García Sánchez
Nick Rehm
aeropic
StormingMoose
Taiwo
