Papaya Pathfinder
Papaya Pathfinder patch
Papaya Pathfinder is an open-source family of small remote-controlled rovers based on the ESP32.
The project currently includes two rover variants, designed for different sizes, motors, and power requirements.
All mechanical parts of the rovers are fully 3D-printable, and all models are available in the 3d-models/ directories of each rover variant.
The rovers can be operated using either WiFi or ExpressLRS (ELRS), depending on the firmware configuration.
Papaya Pathfinder
Firmware
The rover supports multiple firmware configurations, each enabling a different communication method.
3D-Printed Parts
Printables
Papaya Pathfinder model
All STL files for this rover are available in: pathfinder/3d-models/
The complete mechanical design is also available in STEP format: pathfinder/cad/papaya-pathfinder.step
Use PETG or PLA for the structural parts, and TPU for the tires. All parts are designed to be assembled using M3 screws and nuts.
File Qty Material Notes
body.stl 1 PETG / PLA Main chassis
arm_left.stl 1 PETG / PLA Left suspension arm
arm_right.stl 1 PETG / PLA Right suspension arm
pivot_left.stl 1 PETG / PLA Left pivot mount
pivot_right.stl 1 PETG / PLA Right pivot mount
differential_bar.stl 1 PETG / PLA Central rocker-bogie differential bar
differential_link_left.stl 1 PETG / PLA Left link between differential bar and suspension arm
differential_link_right.stl 1 PETG / PLA Right link between differential bar and suspension arm
motor_mount.stl 4 PETG / PLA Motor mounts for GA25 motors used on steering arms
horn_adapter.stl 4 PETG / PLA Servo horn adapters for steering servos. Print horizontally for strength.
rim.stl 6 PETG / PLA Wheel rims
tire.stl 6 TPU Tires
Papaya Pathfinder Mini
Firmware
3D-Printed Parts
Printables
Papaya Pathfinder Mini model
All STL files for this rover are available in: pathfinder-mini/3d-models/
The complete mechanical design is also available in STEP format: pathfinder-mini/cad/papaya-pathfinder-mini.step
differential_bar.stl 1 PETG / PLA Central differential bar for the rocker-bogie suspension
differential_link.stl 2 PETG / PLA Links between the differential bar and each suspension arm
motor_retainer.stl 6 PETG / PLA Holds each N20 motor
License
This project is licensed under the Apache License 2.0.
See the LICENSE file for details.
