Working in progress
A project log for An handheld Framework PC (the not easy way)
I plan to build my dream PC.
gguussssgussgguussss.guss 6 hours ago0 Comments
I have printed mechanicals parts to build a first prototype.
I have just received a display panel (TL070FVXS02)
I'm  working on creation a eDP cable between  motherboard and display panel
Display Interface Motherboard side
IPEX 20879-040E connector used to interface to an eDP display.  Note that there are signals
defined for both USB 2.0 and I2C touchscreens.  There is a PWM interface to control backlight
brightness, but the display currently used on the Framework Laptop converts that to a DC LED
control.  Note that pin 1 is on the left when looking at the receptacle on the Mainboard.
| Pin | Signal      | Description            |
| 1   | BL_POWER    | 12-17V backlight power |
| 2   | BL_POWER    |                        |
| 3   | BL_POWER    |                        |
| 4   | NC          |                        |
| 5   | GND         |                        |
| 6   | AUXP        |                        |
| 7   | AUXN        |                        |
| 8   | GND         |                        |
| 9   | EDP_TXP_0   |                        |
| 10  | EDP_TXN_0   |                        |
| 11  | GND         |                        |
| 12  | EDP_TXP_1   |                        |
| 13  | EDP_TXN_1   |                        |
| 14  | GND         |                        |
| 15  | EDP_TXP_2   |                        |
| 16  | EDP_TXN_2   |                        |
| 17  | GND         |                        |
| 18  | EDP_TXP_3   |                        |
| 19  | EDP_TXN_3   |                        |
| 20  | GND         |                        |
| 21  | EDP_HPD     | hotplug                |
| 22  | BLK_PWM_LCD | Backlight PWM          |
| 23  | BLK_OFF_N   | Backlight Enable       |
| 24  | NC          |                        |
| 25  | NC          |                        |
| 26  | 3V_EDP      | 3VS                    |
| 27  | 3V_EDP      |                        |
| 28  | 3V_EDP      |                        |
| 29  | 3V_TS       | 3VS for touchscreen    |
| 30  | 3V_TS       |                        |
| 31  | USB_DP      | USB                    |
| 32  | USB_DN      |                        |
| 33  | TS_EN       |                        |
| 34  | TS_RST      |                        |
| 35  | TS_INT_N    |                        |
| 36  | TS_SDA      |                        |
| 37  | TS_SCL      |                        |
| 38  | NC          |                        |
| 39  | GND         |                        |
| 40  | GND         |                        |
Connector: 20682-040E-02 Panel side
Pin No. Symbol Function Remark
1 NC/SCL I2C SCL for DDS function
2 GND Ground
3 Lane1_N EDP Data Lane 1N
4 Lane1_P EDP Data Lane 1P
5 GND Ground
6 Lane0_N EDP Data Lane 0N
7 Lane0_P EDP Data Lane 0P
8 GND Ground
9 TCH_I2C_SCL Touch I2C Interface : Clock Input
10 TCH_I2C_SDA Touch I2C Interface : Data Input / Output
11 GND Ground
12 TCH_ATTN Touch Interrupt Pin
13 TP VCC TP Digital Power Supply
14 GND Ground
15 AUX_CH_P EDP AUX Lane P
16 AUX_CH_N EDP AUX Lane N
17 GND Ground
18 LCD_VCC LCM Digital Power Supply, (TYP. 3.3V)
19 LCD_VCC LCM Digital Power Supply, (TYP. 3.3V)
20 LCD_VCC LCM Digital Power Supply, (TYP. 3.3V)
21 LCD_VCC LCM Digital Power Supply, (TYP. 3.3V)
22 FRM Reserved for LCD Panel Self Test Enable
23 LCD_GND Ground
24 LCD_GND Ground
25 LCD_GND Ground
26 LCD_GND Ground
27 HPD Hot Plug Detection pin for EDP
28 BL_GND Back Light Ground
29 BL_GND Back Light Ground
30 BL_GND Back Light Ground
31 BL_GND Back Light Ground
32 BL_ENABLE Backlight On / Off
33 BL_PWM DIM System PWM signal Input
34 Touch_EN Touch Function Enable Pin
35 NC/SDA I2C SDA for DDS function
36 BL_PWR Backlight power (5V~21V)
37 BL_PWR Backlight power (5V~21V)
38 BL_PWR Backlight power (5V~21V)
39 BL_PWR Backlight power (5V~21V)
40 APOLC APOL function(High enable
