An handheld Framework PC (the not easy way)
I plan to build my dream PC.
Public Chat
0 followers
My project is to build an handled PC based on AMD Ryzen 7 7840 Framework 13 laptop motherboard.
I planed to use the eDP port on the motherboard to connect a display, no usb to hdmi adapter.
I would like to have modular controllers, especially using a mini trackball.
In the future, I also would like to use the other internal motherboard connectors to add a mini keyboard, camera and mic.
After discovering the motherboard of the AMD Ryzen 7 7840 series from Framework, I said to myself that it was, for me, the ideal platform to make a handled version.
I was able to see various interesting projects, but all of them used USB C ports as an interface for the display.
I said to myself that will be smart to use the motherboard's eDP ports for this type of project, since Framework provides all the information necessary for its use.
So I started researching how to use this eDP port. I noticed that there were not many different screen models and came across the screen models intended in particular for the ROG Ally, Lenovo Legion Go.... which are either 7" 1920x1080@120hz. TL070FVXS01-02, ZS070FHT-L41 or 8" 1920x1200@120hz NS080WUM-LX1
I had to look for the documentation for these screens to get the pinout, I only found it for the TL070FVXS01-02.
I also started drawing mechanical elements to print in 3D.
My project is also to have modular controllers, i would like to integrate a mini trackball, like
I would like to use internal mother board connectors to let USB C accessible to external stuffs'.
  • 1 × Motherboard Framework Laptop 13 Mainboard (AMD Ryzen™ 7040 Series)
  • 1 × Battery Evaluation, Demonstration Kits, Boards and Modules / Evaluation Kits, Boards and Modules
  • 1 × Speakers kit Framework Laptop 13 Speaker Kit
  • 1 × Audio board Framework Laptop 13 Audio Board Kit
  • 1 × Wifi board AMD RZ616 Wi-Fi 6E
View all 6 components
  • Working in progress
    gguussss.guss6 hours ago 0 comments
    I have printed mechanicals parts to build a first prototype.
    I have just received a display panel (TL070FVXS02)
    I'm  working on creation a eDP cable between  motherboard and display panel
    Display Interface Motherboard side
    IPEX 20879-040E connector used to interface to an eDP display.  Note that there are signals
    defined for both USB 2.0 and I2C touchscreens.  There is a PWM interface to control backlight
    brightness, but the display currently used on the Framework Laptop converts that to a DC LED
    control.  Note that pin 1 is on the left when looking at the receptacle on the Mainboard.
    | Pin | Signal      | Description            |
    | 1   | BL_POWER    | 12-17V backlight power |
    | 2   | BL_POWER    |                        |
    | 3   | BL_POWER    |                        |
    | 4   | NC          |                        |
    | 5   | GND         |                        |
    | 6   | AUXP        |                        |
    | 7   | AUXN        |                        |
    | 8   | GND         |                        |
    | 9   | EDP_TXP_0   |                        |
    | 10  | EDP_TXN_0   |                        |
    | 11  | GND         |                        |
    | 12  | EDP_TXP_1   |                        |
    | 13  | EDP_TXN_1   |                        |
    | 14  | GND         |                        |
    | 15  | EDP_TXP_2   |                        |
    | 16  | EDP_TXN_2   |                        |
    | 17  | GND         |                        |
    | 18  | EDP_TXP_3   |                        |
    | 19  | EDP_TXN_3   |                        |
    | 20  | GND         |                        |
    | 21  | EDP_HPD     | hotplug                |
    | 22  | BLK_PWM_LCD | Backlight PWM          |
    | 23  | BLK_OFF_N   | Backlight Enable       |
    | 24  | NC          |                        |
    | 25  | NC          |                        |
    | 26  | 3V_EDP      | 3VS                    |
    | 27  | 3V_EDP      |                        |
    | 28  | 3V_EDP      |      ...
View project log
Per Jensen wrote 02/02/2026 at 12:49 point
"handled" or "handeled" - you mean handheld?
gguussss.guss wrote 7 hours ago point
oh, yes, you are right, this is "handheld" i mean.
