An open-source - community built micro-inverter
Manifesto
The project goal are :
- Having the first open source PV micro-inverter
- Finally a design easy to repair that is no longer a black box
- Redeem your data sovereignty, you will no longer depend on a proprietary cloud to follow your solar production and consumption.
Open, for everyone, forever
- This project is propulsed by its community.
- The collective work generated is meant to remain open.
- Design files are made with open source software - Namely kiCAD.
- Mechanical interfaces and components are modeled using FreeCAD.
- Simulation files use ngSpice.
In that sense, the owntech foundation aims at protecting this technical common.
Specifications
This section is inspired from OpenMi.
Comparison of micro-inverters with rated output power between 350VA and 400VA is given in the project github repository.
uVerter Target specifications
| Category | Requirement | Notes |
| Grid | 230VAC - 50Hz | Designed for EU style grids |
| Grid compliance | Grid-code compliant | Exact certification scope depends on country/standard |
| Rated apparent power | 450VA | Software-limited power cap supported |
| Input DC operation range | 16V - 58V | PV module operating window |
| Recommended PV input power | 350W - 550W | Depends on module and thermal conditions |
| Efficiency | >95% | Target nominal conditions |
| Power factor | ≈ 1 | Near-unity PF at rated power |
| THD | <5% | Total harmonic distortion at rated conditions |
| Isolation | Galvanic isolation | Electrical isolation between PV and grid |
| Operating temperature | -40 °C to +60 °C | Derating may apply |
| Repairability | No invasive potting | Designed to be serviceable and inspectable |
| Connectivity | Wi-Fi | Local-first monitoring (no proprietary cloud required) |
Standards and directives
- IEC 62109: Safety requirements for photovoltaic inverters.
- IEC 61727: Requirements for photovoltaic (PV) systems to interface with the utility grid.
- IEC 62116: Test procedure for islanding prevention measures for utility-interconnected photovoltaic inverters.
- EN 50438: Requirements for the connection of micro-generators in parallel with public low-voltage distribution networks.
- EN 50549: Requirements for generating plants to be connected in parallel with distribution networks (superseeds DIN VDE 0126)
Licence
This project is licenced under **CERN-OHL-V2-S** open source hardware licence. Licence file can be found under `License/cern-ohl-v2-s`.
Luiz Villa
Joey Byrnes
Tristan
SDCforAll
