FPU Particle Animation demo
A project log for MC68881 VHDL
This project is an open source implementation of the Motorola MC68881 floating-point unit written in VHDL
matthew-pearceMatthew Pearce 03/19/2026 at 10:350 Comments
Demo of fireworks using the FPU on xilinx hardware with 68000 processor in arm emulation
#include <stdio.h>
#include <math.h>
#include "../lib/merlin2_gfx.h"
#include "../lib/merlin2_rand.h"
/* 640x480 viewport centred on 1280x720 framebuffer */
#define VP_W    640
#define VP_H    480
#define VP_X    320
#define VP_Y    120
_Static_assert(VP_X + VP_W <= GFX_SCREEN_W, "Viewport exceeds screen width");
_Static_assert(VP_Y + VP_H <= GFX_SCREEN_H, "Viewport exceeds screen height");
/* Physics */
#define GRAVITY     0.06f
#define PARTICLES_PER_BURST 32
/* Rocket states */
#define ROCKET_DEAD    0
#define ROCKET_RISING  1
#define ROCKET_BURST   2
typedef struct {
    float x, y;
    float dy;
    float target_y;
    uint32_t colour;
    int state;
} rocket_t;
typedef struct {
    float x, y;
    float old_x, old_y;
    float vx, vy;
    uint32_t colour;
    int life;
    int max_life;
} particle_t;
static rocket_t rocket;
static particle_t particles[PARTICLES_PER_BURST];
static const uint32_t palette[] = {
    0xFFFF2020,  /* red */
    0xFFFFD700,  /* gold */
    0xFF20FF20,  /* green */
    0xFF4080FF,  /* blue */
    0xFFFFFFFF,  /* white */
    0xFFFF40FF,  /* magenta */
#define PALETTE_SIZE (sizeof(palette) / sizeof(palette[0]))
static inline void put_pixel(int x, int y, uint32_t argb)
    if ((unsigned)x < VP_W && (unsigned)y < VP_H)
        *gfx_fb_ptr(x + VP_X, y + VP_Y) = argb;
static uint32_t dim_colour(uint32_t colour, int life, int max_life)
    if (max_life <= 0 || life <= 0)
        return 0xFF000000;
    unsigned r = (colour >> 16) & 0xFF;
    unsigned g = (colour >> 8) & 0xFF;
    unsigned b = colour & 0xFF;
    r = r * (unsigned)life / (unsigned)max_life;
    g = g * (unsigned)life / (unsigned)max_life;
    b = b * (unsigned)life / (unsigned)max_life;
    return 0xFF000000 | (r << 16) | (g << 8) | b;
static void spawn_rocket(void)
    rocket.x = (float)rand_range(120, VP_W - 120);
    rocket.y = (float)(VP_H - 1);
    rocket.dy = -4.0f - (float)rand_range(0, 15) * 0.1f;
    rocket.target_y = (float)rand_range(80, VP_H / 3);
    rocket.colour = palette[rand_range(0, (int)PALETTE_SIZE - 1)];
    rocket.state = ROCKET_RISING;
static void burst_rocket(void)
    float speed_base = 1.5f;
    int i;
    for (i = 0; i < PARTICLES_PER_BURST; i++) {
        particle_t *p = &particles[i];
        float angle = (float)i * (2.0f * (float)M_PI / (float)PARTICLES_PER_BURST);
        float speed = speed_base + (float)rand_range(0, 10) * 0.1f;
        p->x = rocket.x;
        p->y = rocket.y;
        p->old_x = rocket.x;
        p->old_y = rocket.y;
        p->vx = cosf(angle) * speed;
        p->vy = sinf(angle) * speed;
        p->colour = rocket.colour;
        p->max_life = rand_range(30, 50);
        p->life = p->max_life;
    rocket.state = ROCKET_BURST;
static int update_and_draw(void)
    int alive = 0;
    int i;
    /* Update rocket */
    if (rocket.state == ROCKET_RISING) {
        /* Erase old position */
        put_pixel((int)rocket.x, (int)rocket.y + 1, 0xFF000000);
        rocket.y += rocket.dy;
        /* Draw rocket */
        put_pixel((int)rocket.x, (int)rocket.y, 0xFFFFFFFF);
        if (rocket.y <= rocket.target_y)
            burst_rocket();
    /* Update particles */
        if (p->life <= 0)
            continue;
        /* Erase at old position */
        put_pixel((int)p->old_x, (int)p->old_y, 0xFF000000);
        /* Physics */
        p->vy += GRAVITY;
        p->old_x = p->x;
        p->old_y = p->y;
        p->x += p->vx;
        p->y += p->vy;
        p->life--;
        /* Bounds check */
        if ((int)p->x < 0 || (int)p->x >= VP_W ||
            (int)p->y < 0 || (int)p->y >= VP_H) {
            p->life = 0;
            continue;
        /* Draw at new position with fading colour */
        uint32_t c = dim_colour(p->colour, p->life, p->max_life);
        put_pixel((int)p->x, (int)p->y, c);
        alive++;
    return alive;
int main(void)
    int i;
    printf("Fireworks demo - press any key to exit\n");
    rand_seed(gfx_get_time());
    gfx_set_mode(1);
    gfx_clear(0xFF000000);
    rocket.state = ROCKET_DEAD;
        particles[i].life = 0;
    spawn_rocket();
    while (!gfx_char_ready()) {
        int alive = update_and_draw();
        /* Spawn next rocket when current burst dies */
        if (rocket.state != ROCKET_RISING && alive == 0)
            spawn_rocket();
    gfx_set_mode(0);
    printf("Done.\n");
    return 0;
Sample Assembler:
| fireworks.c:129:         p->vy += GRAVITY;
    fmove.s 20(%a2),%fp1    | MEM[(float *)_191 + 20B], _41
    fadd.s #0x3d75c28f,%fp1    |, _41
    fmove.s %fp1,20(%a2)    | _41, MEM[(float *)_191 + 20B]
| fireworks.c:130:         p->old_x = p->x;
    fmove.s (%a2),%fp0    | MEM[(float *)_191], _42
    fmove.s %fp0,8(%a2)    | _42, MEM[(float *)_191 + 8B]
| fireworks.c:131:         p->old_y = p->y;
    move.l 4(%a2),%d0    | MEM[(float *)_191 + 4B], _43
    move.l %d0,12(%a2)    | _43, MEM[(float *)_191 + 12B]
| fireworks.c:132:         p->x += p->vx;
    fadd.s 16(%a2),%fp0    | MEM[(float *)_191 + 16B], _45
    fmove.s %fp0,(%a2)    | _45, MEM[(float *)_191]
| fireworks.c:133:         p->y += p->vy;
    fadd.s %d0,%fp1    | _43, _46
    fmove.s %fp1,4(%a2)    | _46, MEM[(float *)_191 + 4B]
| fireworks.c:134:         p->life--;
    lea (-1,%a1),%a5    |, _35, _47
    move.l %a5,28(%a2)    | _47, MEM[(int *)_191 + 28B]
| fireworks.c:137:         if ((int)p->x < 0 || (int)p->x >= VP_W ||
    fintrz.x %fp0,%fp0    | _45, tmp196
    fmove.l %fp0,%d7    | tmp196, _48
