GNSS-SDR-meets-Arduino-Q
An embedded application of GNSS-SDR running in real time on the Arduino UNO Q platform
Public Chat
0 followers
The Arduino UNO Q runs a Debian-based Linux distribution, which enables native installation of GNU Radio and GNSS-SDR. The complete GNSS-SDR software stack is built directly on the target following the official GNSS-SDR build and installation instructions provided by the GNSS-SDR project.
In its current configuration, the receiver supports GPS L1 C/A only. Multi-constellation operation (e.g., Galileo) is not yet enabled due to computational and memory constraints of the platform.
The system integrates:
Real-time GNSS-SDR processing
A Node.js web server for remote control
A Python interface for data extraction
An STM32F0 microcontroller driving an LED matrix for live visualization
All details can be found in
https://github.com/kalmancito/GNSS-SDR-meets-Arduino-Q
This work is released under the GNU General Public License v2.0 (GPL-2.0).
  • 1
    Hardware setup
    The hardware configuration used in this project consists of:
    • Arduino UNO Q
      • Linux host (Debian-based)
      • STM32F0 microcontroller
    • RTL-SDR front-end
      • Nooelec NESDR SmarTee SDR
    • Active GNSS antenna
    • LED matrix display driven by the STM32F0 MCU
  • 2
    System architecture
    System architecture
  • 3
    GNSS processing configuration
    Real-time GNSS processing is performed using the following configuration:
    • Constellation: GPS
    • Signal: GPS L1 C/A
    • Number of tracking channels: 7
    • Coherent integration time: 4 ms
    • Front-end: RTL-SDR (live RF input)
    The receiver computes standard GNSS outputs in real time, including:
    • GPS observables
    • Carrier-to-noise density ratio (C/N₀)
    • Position, Velocity, and Time (PVT) solution
    Galileo signal processing is currently not enabled due to platform resource limitations.
View all 7 instructions
