## 🏆 ACHIEVEMENTS UNLOCKED ### Historic First ✅ **FIRST documented successful build of:** - Pwnagotchi on Raspberry Pi Zero 2 W - Debian Trixie (testing) - Kernel 6.12.62 - Nexmon WiFi monitor mode on 6.12 - stable-baselines3 2.x integration - Complete deployment pipeline ### Technical Victories ✅ Nexmon firmware compiled for kernel 6.12.62 ✅ Python 3.13 environment working ✅ stable-baselines3 2.7.1 integrated ✅ Display drivers configured (mhs35ips for Sunfounder) ✅ USB gadget networking functional ✅ Web UI accessible and working ✅ Manual and auto modes operational ✅ Image backup created (128GB) ✅ Deployment validated (64GB) ### Documentation Created ✅ Comprehensive GitHub repository ✅ Complete BUILD-GUIDE.md (35KB) ✅ QUICK-REFERENCE.md cheat sheet (15KB) ✅ TROUBLESHOOTING.md guide (30KB) ✅ Example configuration files ✅ 3,334 lines of tested documentation --- ## 🔑 KEY DISCOVERIES ### 1. USB Gadget WiFi Exclusivity (CRITICAL!) **Hardware limitation:** Pi Zero 2 W cannot use USB gadget mode AND WiFi simultaneously! - **Development:** USB connected = No WiFi (SSH + internet) - **Operation:** USB disconnected = WiFi active (monitor mode) - This defined the entire two-phase workflow ### 2. Display Driver Compatibility **Sunfounder MS 3.5 IPS requires mhs35ips driver**, NOT Waveshare drivers! - Wrong driver = wrong colors - Correct driver = perfect display - Critical for user experience ### 3. Python 3.13 Breaking Changes - `distutils` removed - `gym` → `gymnasium` - stable-baselines3 1.x incompatible - Need version 2.7.1+ ### 4. Nexmon Kernel 6.12 Success **First successful port** using DrSchottky's fork - BCM43436b0 chipset - Monitor mode functional - Deauth disabled for stability ### 5. Image Deployment Works 128GB build card successfully clones to 64GB production card - Actual usage: ~10GB - Auto-resize on first boot - Reproducible deployment --- ## 📊 FINAL STATISTICS **Build Sessions:** 4 major sessions **Issues Resolved:** 16+ blocking problems **Commands Documented:** 200+ **Files Created:** 10+ documentation files **Documentation Size:** ~100KB **GitHub Stars:** TBD (when made public) **Most Time-Consuming Issues:** 1. USB/WiFi conflict discovery (2 hours) 2. Display color fix (1.5 hours) 3. stable-baselines3 migration (2 hours) 4. Python dependency resolution (1.5 hours) --- ## 🗂️ FILE LOCATIONS ### GitHub Repository **URL:** https://github.com/SpiritualCreations42/pwnagotchi-pi-zero-2w-guide **Local:** C:\Users\Spiri\Desktop\pwnagotchi-pi-zero-2w-guide\ **Status:** Private (ready to make public) ### Obsidian Vault Documentation **Location:** C:\Users\Spiri\Desktop\Obsidian Vault\Pwnagotchi\ **Session Files:** - Pwnagotchi-Build-Guide-Session1.md - Pwnagotchi-Build-Guide-Session2.md - Pwnagotchi-Build-Guide-Session3.md - Pwnagotchi-Build-Guide-Session4.md ### Master Image **Location:** Aurora Pi5 (need to document exact path) **Filename:** pwnagotchi-pi0-2w-trixie-complete.img **Size:** ~10GB (compressed from 128GB card) ### Working System **Hardware:** Raspberry Pi Zero 2 W **Display:** Sunfounder MS 3.5 IPS SP 125MHz **SD Card:** 64GB SanDisk Ultra **Status:** Fully operational ✅ --- ## 🎯 NEXT STEPS (If Revisiting) ### Immediate Enhancements - [ ] Test standalone mode thoroughly (USB disconnected) - [ ] Verify handshake captures over time - [ ] Document actual WiFi scanning results - [ ] Performance benchmarks ### Optional Features - [ ] GPS module integration - [ ] Bluetooth tethering - [ ] Custom plugins - [ ] Battery operation guide - [ ] 3D printed case design ### Community Sharing (When Ready) - [ ] Make GitHub repo public - [ ] Post to r/pwnagotchi - [ ] Share on Raspberry Pi forums - [ ] Announce on Pwnagotchi Discord - [ ] Write blog post --- ## 💡 LESSONS LEARNED ### Technical 1. **Always check hardware limitations first** - USB/WiFi conflict wasted hours 2. **Driver compatibility matters more than expected** - Display colors 3. **Kernel...Read more »
RzR
Yann Guidon / YGDES
Nick
tomwsmf
