Finally done
A project log for Pwnagotchi+Fancygotchi
Building on Pios Trixie 64bit, with a 3.5" touchscreen
spiritualcreations42SpiritualCreations42 02/11/2026 at 12:310 Comments
# Contributing to Pwnagotchi Pi Zero 2 W Guide
Thank you for your interest in contributing! 🎉
This guide is the result of systematic troubleshooting and comprehensive documentation. We welcome contributions that maintain this standard of quality.
## 🤝 How to Contribute
### Reporting Issues
**Before opening an issue:**
1. Search existing issues (including closed ones)
2. Try the troubleshooting guide
3. Test on a clean installation if possible
**When reporting bugs:**
- Use the issue template (if available)
- Include full error messages
- Provide system information (OS, kernel, hardware)
- Describe steps to reproduce
- Include what you've already tried
**Example good bug report:**
Title: Monitor mode not working after reboot
Hardware: Pi Zero 2 W
Kernel: 6.12.62+rpt-rpi-v8
OS: Debian Trixie
Description:
After rebooting the Pi, mon0 interface doesn't get created.
USB is disconnected. Nexmon appears to load (checked dmesg).
Steps to reproduce:
1. Fresh install following BUILD-GUIDE.md
2. Verify mon0 works initially
3. Reboot
4. mon0 not present
Already tried:
- Checking USB is disconnected
- Verifying Nexmon firmware is present
- Checking systemd logs
Logs:
[paste relevant logs here]
### Suggesting Enhancements
We welcome suggestions for:
- Improved documentation clarity
- Additional hardware compatibility
- New features or workflows
- Better troubleshooting steps
**Good enhancement requests include:**
- Clear description of the problem/need
- Proposed solution
- Why this would help others
- Any implementation details
### Contributing Code/Documentation
#### Documentation Improvements
**We especially welcome:**
- Clarifications for confusing steps
- Additional examples
- Better explanations
- Corrections for errors
- New hardware compatibility info
- Alternative methods that work
**Guidelines:**
- Keep the same friendly, clear tone
- Use emoji sparingly but appropriately
- Include code blocks with proper syntax highlighting
- Test all commands/procedures before submitting
- Maintain the "written for someone forgetful" approach
#### Code Contributions
**For scripts and utilities:**
- Follow existing code style
- Add comments explaining non-obvious parts
- Test thoroughly on Pi Zero 2 W
- Document any dependencies
- Include usage examples
#### Pull Request Process
1. **Fork the repository**
2. **Create a branch:**   ```bash   git checkout -b feature/your-feature-name   ```
3. **Make your changes:**   - Follow existing structure and style   - Test everything thoroughly   - Update relevant documentation
4. **Commit with clear messages:**   ```bash   git commit -m "Add: Clear description of what you changed"   ```      **Good commit messages:**   - `Fix: Correct Nexmon build commands for kernel 6.12.65`   - `Add: Hardware compatibility info for WaveShare 4" display`   - `Improve: Clarify USB gadget conflict in BUILD-GUIDE.md`   - `Docs: Fix typo in TROUBLESHOOTING.md`
5. **Push to your fork:**   ```bash   git push origin feature/your-feature-name   ```
6. **Open a Pull Request**   - Clear title describing the change   - Reference any related issues   - Describe what you changed and why   - Include testing details
## 📝 Documentation Standards
### Writing Style
- **Clear and concise** - No unnecessary jargon
- **Step-by-step** - Assume reader is following along
- **Tested procedures** - Every command should be verified
- **Helpful warnings** - Use ⚠️ for critical information
- **Checkpoints** - Include ✅ validation steps
### Formatting
**Use consistent markdown:**
```markdown
### Section Heading
**Bold for emphasis** on important concepts
`Code formatting` for commands and filenames
```bash
# Code blocks with syntax highlighting
command --with-flags
- Bullet lists for options
- Numbered lists for sequences
> **Note:** Information boxes for tips
⚠️ **Warning:** Critical information
✅ **Success:** Validation checkpoints
**File paths:**
- Use absolute paths: `/etc/pwnagotchi/config.toml`
- Not: `config.toml`
**Commands:**
- Show full commands: `sudo systemctl restart pwnagotchi`
- Not: `restart the service`
## 🧪 Testing Requirements
**Before submitting:**
1. **Test on clean installation**   - Fresh Raspberry Pi OS Lite   - Follow your modified procedure   - Document any issues
2. **Verify all commands work**   - No typos   - Correct syntax   - Expected output matches
3. **Check documentation renders correctly**   - Preview markdown locally   - Verify links work   - Check formatting
4. **Test edge cases**   - What if command fails?   - What if file doesn't exist?   - Include error handling
## 🎯 Priority Areas
We especially need help with:
1. **Hardware Testing**   - Testing on different Pi models (Pi 3/4/5)   - Different display compatibility   - Other WiFi chipsets
2. **Documentation Improvements**   - Simpler explanations   - More examples   - Better troubleshooting
3. **Alternative Methods**   - Different build approaches   - Performance optimizations   - Plugin examples
4. **Internationalization**   - Translations   - Region-specific notes
## ❌ What We Don't Accept
- Incomplete or untested changes
- Breaking existing functionality
- Removing safety warnings
- Encouraging illegal activity
- Poorly documented code
- Plagiarized content
## 📜 Code of Conduct
### Our Standards
- **Be respectful** - Different skill levels, be patient
- **Be constructive** - Criticism should be helpful
- **Be collaborative** - Work together to solve problems
- **Be inclusive** - Welcome all contributors
- **Assume good faith** - People are trying to help
### Unacceptable Behavior
- Harassment or discriminatory language
- Personal attacks
- Trolling or deliberately unhelpful responses
- Spam or off-topic discussions
- Sharing others' private information
## 📞 Questions?
- **Documentation questions:** Open a Discussion
- **Bug reports:** Open an Issue
- **Feature requests:** Open an Issue with [FEATURE] tag
- **Security issues:** Email privately (don't open public issue!)
## 🏆 Recognition
Contributors will be:
- Listed in a CONTRIBUTORS.md file
- Credited in relevant documentation
- Thanked in release notes
We value all contributions, big or small! 💪
## 📚 Resources
- [BUILD-GUIDE.md](docs/BUILD-GUIDE.md) - Full build procedure
- [TROUBLESHOOTING.md](docs/TROUBLESHOOTING.md) - Known issues
- [QUICK-REFERENCE.md](docs/QUICK-REFERENCE.md) - Command reference
<p align="center">  <strong>Thank you for helping make this guide better! 🎉</strong><br>  <em>Every contribution helps someone build their Pwnagotchi successfully!</em>
</p>
