nRF9151 MicroMod Processor
Add LTE-M, NB-IoT, DECT-NR+, and GNSS functionality to your MicroMod project
nRF9151 MicroMod Processor is based on the nRF9151 System in Package from Nordic Semiconductor. It has an M.2 E-Key connector and is compatible with SparkFun’s MicroMod ecosystem. This 22x22 mm board brings LTE-M, NB-IoT, NB-NTN and DECT-NR+ communication, as well as GNSS functionality, to the MicroMod ecosystem. It has external flash memory to offer remote firmware upgrades and an additional GPIO expander to access almost all of the MicroMod pins.
Unleash the Power of Cellular IoT
This compact 22x22 mm board is designed to seamlessly integrate into the SparkFun MicroMod ecosystem, offering a wealth of communication possibilities for projects. Whether you’re working on remote monitoring, irrigation systems, or asset tracking, the nRF9151 MicroMod Processor provides the tools needed to connect and control devices from anywhere. With its open pinout based on the M.2 E-Key connector, it is easy to combine it with various MicroMod carrier and function boards to create a custom IoT solution without the hassle of soldering.
Features & Specifications
  • nRF9151 SiP
  • Nano SIM card holder
  • NOR flash to support OTA
  • 16 bit (open-drain) GPIO expander to access almost all MicroMod pins
Crowd Supply
I am happy to share that the nRF9151 MicroMod Processor will soon be available on Crowd Supply. The pre-launch page is already online. Subscribe on Crowd Supply to stay up to date and get notified when the crowd funding starts: https://www.crowdsupply.com/hirsch-zone/nrf9151-micromod-processor
View project log
