Trixel LED Mini Panel V01
05/25/2018 at 10:18 • 0 commentsAfter assembling a few dozen of Triangles / Square, I figured its time to design something more easy to assemble. First conclusion was that a led at both sides may be fun, but is much harder for production either by hand or by machine. So the first move was to design a single side led elements. (Available on GitHub ). For the second conclusion i figured its time to work on paneling the elements, so that the assembly process will be on multiple boards simultaneously.
As for the elements, I have learned a bit more proper design and implemented that in the new files, making the design a bit cleaner, and implementing a small robustness in the circuit by adding a limiting resistor for each led output. in order to help saving the led in case of shorts for the output. In addition the transition to single side leds allows soldering 2 boards back to back, and by that increasing the flexibility to route the leds in different directions while keeping the option for leds on both side of a pcb ( making a thicker PCB).
Creating a good panel requires some experience, and for that I am highly grateful for the huge amount of feedback and suggestion I got from Dan at OSHPARK He definitely saved me several iterations. From the experience I can provide my two cents for paneling a PCB.
There are various documentations as for how to make a panel and the available methods, V - cut, stamp holes. milling etc. each manufacturer has it`s one requirements and before applying a design I suggest reading thoroughly the documentation from the specific manufacturer.
Since most of my board has castellated holes, i chose to use the stamp holes method to separate the boards, easy said hard to implement. Since there are various requirements for stamp hole diameter and the distance from the holes which will influence how easy the boards will be separated while not falling apart during manufacturing. OSHPARK has a great documentation for that with a few suggestion.
My work method iclude working both with eagle and fusion360, since autodesk has bought eagle the programs are becoming more "friendly" with each other. I start designing with fusion360 since you can make the design parametric and easy to change.
After some experimenting and attempts, I have chosen stamp holes at 0.02in (0.5 mm) diameter, and at a distance of 0.04in (1 mm). positioning them on the outer edge of the board. The milling space was set to 1 in (2.5 mm). The design results looked like that. (and available here: Trixel Mini Panel Fusion360)
From here I export the design as a dxf file to be imported into eagle. One for the stamp holes position which are implemented for the elements, and another for the panel file which should be the dimension layer in eagle. since the eagle import dxf isn`t perfect, some manual fixes are required. Here is the result after duplicating the triangles into the panel file.
In order to be able to separate the boards from the panel some stamp holes were added allowing to break the panel. ( Thank you Dan , you have definitely saved me an iteration here). The Panel stamp holes are a bit larger, 0.4 in ( 1 mm ) at a distance of 0.6 in ( 1.5 mm ).
Breaking of the boards out of the panel is highly satisfying :)
The separated boards look awesome and now it is the time to make something of them.
I have decided to make a closed shape out of the new triangles, and the easiest is 2 half's of 5 triangles each.
Adding some diffuser elements:
And that is how it looks
Some conclusions:
- Assembling a panel is way way faster. especially applying the solder paste.
- The boards snap out quite easy, but i would suggest a bit larger stamp holes for the triangles or positioning them a bit closer. I think this is something which is needed to be discussed with the manufacturer since not every design is acceptable. The risk that the elements will break out during manufacturing may cause them to reject your design.
- for closed shapes i will need to design some jigs, as they are not always get aligned properly.
Next version panel will also include the hexagon MCU, 22 triangles and 8 squares. Perhaps the required elements for a sphere made with triangles and squares...
Hexagonal MCU
03/26/2017 at 15:32 • 0 commentsThe first MCU iteration i have tested out was a simple bar, (simple mcu) but after exploring the additional shapes. I have decided to make the MCU as the hexagon shape, since its the repetitive shape of 6 Triangles.
As you can notice I have ordered the pcb`s from OSHPARK (Perfect Purple PCB) , and since discovering how easy it is to assemble boards with a reflow oven, I have added the little bit for a stencil from OSH Stencils.
From there it is as easy as baking a sponge cake. Apply some solder through the stencil, populate the components, 7 minutes in a reflow oven, adding the through hole components by hand ( the crystal ).
And wallha, you have 3 beautiful custom made boards to play with.
Since it is an open source project, and i am using one of the most popular MCU`s at the DIY market, The atmega32u4, I have allowed myself to flash the arduino micro bootloader on the mcu. With the help of the avrisp mk2 programmer and a small adapter board by sparkfun - ISP Pogo Adapter. The pogo pins are very helpful when you don`t want to add unnecessary headers which don`t have any use besides a one time flash of the bootloader.
The boards are ready.... Arduino compatible, and programmed as any arduino pro micro compatible board out there, but in your custom favorite shape.
To test the new boards i have modified a bit the sample code by adafruit ( neoPixels - strandtest ) to work with 5 strands with the addition of some comments to the bootloader and fuses used - strandtest.
After soldering some triangle shaped leds you get a highly satisfying, custom made 3d light fixture :)
The Idea & How it started
03/21/2017 at 14:32 • 0 commentsIdea:
The idea is designing basic elements of addressable LED`s which can be combined into fascinating shapes.
I play a lot with LED`s, mostly the famous addressable LED`s such as the ws2812.
[ Sample projects: https://hackaday.io/project/5466-smart-juggling-balls , https://hackaday.io/project/6039-shakeit, https://hackaday.io/project/7430-chess-timer, https://youtu.be/fSF5rG59FKs . ]
You can get the LED`s in various forms such as strips, circles , Matrixes, bars, (Adafruit has a wide variety of shapes) or you can get them in SMD to design your own two dimensional shape.
Images from: https://www.adafruit.com/
Mostly the forms aren't designed to be soldered together directly, you can solder wires between them but not to create a stand alone form.
Based on this Gap my concept started to formalize.
Design Process:
I have started my design iterations with a simple triangle as a standard base element and hence the name, Trixel - Triangle Pixel:
Later on i have extended the design for a square and a pentagon shapes while maintaining a few guide lines for compatibility between shapes.
Design rules:
- Equilateral shapes, side length 1 inch
- Side connector is a symmetric (V G S G V) 5 pin castellated, spaced at 0.1 inch
- One middle LED
- One input, the rest are potential outputs
Design files (Eagle) are available on GitHub: Trixel-LED
