What does the "eco" button on my fridge do?
A project log for Energy Analytics Dashboard for Tapo / Kasa
Self-hosted Grafana-based energy analytics for TP-Link Tapo and Kasa devices, bundled into a lightweight Docker stack. Deploys in minutes.
ignorant-of-thingsIgnorant of Things a day ago0 Comments
My fridge has a mystery "eco" button on it.  When I press it, it plays a happy tune and a letter "e" shows on the display.  I'd like to think that I'm doing good by my fridge and the environment by pressing it.
But I have no idea.  What does it do?  Is it more economical?  Or am I just being offered... cold comfort? ❄️
To test, I ran the fridge in normal mode for a month, then in another month in eco mode.   I then had a look at weather data for the test period and made sure there were no excessively hot days to skew the results - it's summer at the moment and it reached 44 degrees C here at one point!  Using this data, I selected 10 consecutive days from each sample that were roughly comparable.
Here's what those 10 days look like in full power mode:
And here's the eco mode for the comparison period:
Already, I can see a notably different duty cycle, and the numbers are in!  I'm saving an underwhelming 2c a day 💰 or around 50 watt-hours.  At least I won't die wondering, but with that said... we need to go (slightly) deeper.
Zooming into an 8-hour section of each, the difference in cycles is apparent:
The longer duty cycle is the normal mode, with the shorter/variable duty cycle being the economical mode.  The ramp up and down remains the same, as does the peak power (within a few W), which tells us that only the modulation of the compressor is changed, and it's not otherwise being driven any differently.
The histogram suggests a narrower hysteresis band, giving shorter, more frequent cycles.  If the eco mode is a user setting, it implies some sort of tradeoff... with temperatures being set the same, it may just come down to compressor wear or noise preference 🤷
So, I guess it can stay.  Adjusted for inflation and power price rises, I stand to save maybe $100 over the lifespan of the unit.
